NC55-RP issue
fscarpin
Hi all,
I have issue with NC55-RP card.
this is what I have when I try to do a sw upgrade:
RP/0/RP0/CPU0:Bologna-32#sh install active
Fri Sep  7 12:48:55.503 UTC
Node 0/RP0/CPU0 [RP]
  Boot Partition: xr_lv0
  Active Packages: 1
        ncs5500-xr-7.0.1.20I version=7.0.1.20I [Boot image]
Node 0/1/CPU0 [LC]
  Active Packages: 1
But I cannot going on
RP/0/RP0/CPU0:Bologna-32#sh install log 4
Fri Sep  7 12:49:32.220 UTC
Sep 07 11:57:53 Install operation 4 started by root:
install add source tftp://10.58.244.120/Release/NC55/ ncs5500-isis-2.1.0.0-r70120I.x86_64.rpm
Sep 07 11:57:54 Action 1: install add action started
Sep 07 11:57:54 ERROR! Failed to get staging location. Sysadmin harddisk might be almost full
Sep 07 11:57:54 ERROR! Hard disk is full, install precheck failure
Sep 07 11:57:54 if repository is full, please do
Sep 07 11:57:54 "install remove inactive all" of inactive packages
Sep 07 11:57:54 and retry install operation
Sep 07 11:57:54 ERROR!! failed while getting staging location for add
Sep 07 11:57:56 Install operation 4 aborted
Sep 07 11:57:56 Ending operation 4
RP/0/RP0/CPU0:Bologna-32#sh install  inactive
Fri Sep  7 12:49:59.273 UTC
No inactive package(s) in software repository
RP/0/RP0/CPU0:Bologna-32#sh platform
Fri Sep  7 12:51:03.422 UTC
Node              Type                       State             Config state
0/1/1             NC55-MPA-1TH2H-S           OK
0/1/CPU0          NC55-MOD-A-SE-S            IOS XR RUN        NSHUT
0/1/NPU0          Slice                      UP
0/RP0/CPU0        NC55-RP(Active)            IOS XR RUN        NSHUT
0/FC0             NC55-5504-FC               OPERATIONAL       NSHUT
0/FC1             NC55-5504-FC               OPERATIONAL       NSHUT
0/FC2             NC55-5504-FC               OPERATIONAL       NSHUT
0/FC3             NC55-5504-FC               OPERATIONAL       NSHUT
0/FC4             NC55-5504-FC               OPERATIONAL       NSHUT
0/FC5             NC55-5504-FC               OPERATIONAL       NSHUT
0/FT0             NC55-5504-FAN              OPERATIONAL       NSHUT
0/FT1             NC55-5504-FAN              OPERATIONAL       NSHUT
0/FT2             NC55-5504-FAN              OPERATIONAL       NSHUT
0/PM0             N9K-PAC-3000W-B            OPERATIONAL       NSHUT
0/PM1             N9K-PAC-3000W-B            OPERATIONAL       NSHUT
0/PM2             NC55-PWR-3KW-AC            FAILED            NSHUT
0/SC0             NC55-SC                    OPERATIONAL       NSHUT
clear this directory from admin
"100% /misc/disk1"
6 Replies 6
tkarnani
from xr vm
run df
from admin
run df /misc/disk1
run df -kh
let us see if there is any disk full
RP/0/RP0/CPU0:Bologna-32#run df
Fri Sep 7 14:48:54.397 UTC
Filesystem 1K-blocks Used Available Use% Mounted on
/dev/loop5 4052796 1156412 2670800 31% /
devfs 1024 16 1008 2% /dev
run 12080820 460 12080360 1% /bindmnt_netns
tmpfs 64 0 64 0% /dev/cgroup
/dev/mapper/app_vol_grp-app_lv0 3869352 107600 3545484 3% /misc/app_host
/dev/mapper/panini_vol_grp-host_lv0 991512 434836 489092 48% /dev/sde
tmpfs 12080820 164 12080656 1% /var/volatile
tmpfs 12080820 68 12080752 1% /run
tmpfs 12080820 0 12080820 0% /media/ram
none 12080820 703168 11377652 6% /dev/shm
/dev/mapper/pci_disk1-ssd_disk1_xr_1 38851204 2617856 34236756 8% /misc/disk1
/dev/loop6 469636 27788 406732 7% /var/log
/dev/loop7 469636 888 433632 1% /misc/config
/dev/loop8 2021324 5132 1895464 1% /misc/scratch
none 512 0 512 0% /mnt
sysadmin-vm:0_RP0# run df /misc/disk1
Fri Sep 7 14:49:23.869 UTC+00:00
/dev/mapper/pci_disk1-ssd_disk1_calvados_1 38851204 38834512 0 100% /misc/disk1
sysadmin-vm:0_RP0#
sysadmin-vm:0_RP0# run df -kh
Fri Sep 7 14:49:46.839 UTC+00:00
Filesystem Size Used Avail Use% Mounted on
/dev/loop1 2.4G 1012M 1.3G 45% /
devfs 64K 4.0K 60K 7% /dev
tmpfs 64K 0 64K 0% /dev/cgroup
/dev/loop0 7.4G 984M 6.1G 14% /install/tmp
/dev/mapper/pci_disk1-ssd_disk1_hostos 31G 2.0G 28G 7% /misc/disk1/tftpboot
tmpfs 12G 28K 12G 1% /var/volatile
tmpfs 12G 64K 12G 1% /run
tmpfs 12G 0 12G 0% /media/ram
none 12G 1.3M 12G 1% /dev/shm
/dev/mapper/pci_disk1-ssd_disk1_calvados_1 38G 38G 0 100% /misc/disk1
/dev/loop2 459M 36M 389M 9% /var/log
/dev/loop3 459M 5.9M 419M 2% /misc/config
/dev/loop4 2.0G 3.7M 1.9G 1% /misc/scratch
none 512K 0 512K 0% /mnt
/dev/ubi3_0 15M 652K 13M 5% /mnt/plog
sysadmin-vm:0_RP0#
"100% /misc/disk1"
thanks a lot for your help! it works!
How to clear,could you give me command? Thank you very much
Disk Full
admin
run df /misc/disk1
run
cd /misc/disk1
ls -lrt
rm -f *core*
