NCS 540 XR 6.3.2 / Troubleshooting Interface input drops
dgilbertson
Would any have commands for the NCS 540 to view what drops are occurring on the router?
show drops ;  command doesn't exist
show contr tengig 0/0/0/23 stats ; isn't showing any errors or drops
show contr ?  ; options and output is pretty cryptic
Any suggestions would be appreciated.
#sh int ten 0/0/0/23 | i drop
Fri Nov 30 21:33:40.617 UTC
11346325294 packets input, 3510712998344 bytes, 12759057 total input drops
0 drops for unrecognized upper-level protocol
331548436198 packets output, 74631515816304 bytes, 0 total output drops
9 Replies 9
dgilbertson
Digging through the community posts;  I did find this post with at least is leading me down the right path.
post from: IOS-XR: input drop が断続的にカウントアップする
#show netio drops interface tenGigE 0/0/0/23 location 0/0/cpu0
Fri Nov 30 22:25:29.840 UTC
Interface: TenGigE0/0/0/23 (0x00000258)
Interface input drops: 681451527 pkts
Caps <num> (Protocol <num> Chain):
DLL/function name Address Drop pkts Drop bytes
mpls <25> (mpls <13> decaps):
<unknown> 0x5a033b12 681451527 2230927114
tkarnani
can we check to see if this command is supported on your version of NCS?
show captured packets ingress location 0/x/cpu0
thanks
That command does work.  Here's a snipit of the output.
#show captured packets ingress location 0/0/cpu0
Mon Dec 3 18:11:37.014 UTC
packets dropped in hardware in the ingress direction
buffer overflow pkt drops:240996, current: 200, maximum: 200
[200] Dec 3 18:02:15.494, len: 77, hits: 1, buffhdr type: 1
i/p i/f: TenGigE0/0/0/17
punt reason: DROP_PACKET
Ingress Headers:
port_ifh: 0x228, sub_ifh: 0x0, bundle_ifh: 0x0
logical_port: 0x21, pd_pkt_type: 4
punt_reason: DROP_PACKET (0)
payload_offset: 29, l3_offset: 29
FTMH:
pkt_size: 0x6c, tc: 1, tm_act_type: 0, ssp: 0x21
PPH:
pph_fwd_code: CPU Trap (7), fwd_hdr_offset: 0
inlif: 0x0, vrf: 0xffff, rif: 0x61b
FHEI:
trap_code: Rx_UNKNOWN_PACKET (63), trap_qual: 33
[ether dst: ab00.0002.0000 src: cc8e.7169.9a10 type/len: 0x6002]
Further snipit; looking at just that interface TenGig0/0/0/11 from that command output.   I remove the packet data as it's the same as what I already posted.  As far as the capture output.
[25] Dec 3 16:24:42.610, len: 77, hits: 1, buffhdr type: 1
i/p i/f: TenGigE0/0/0/11
[43] Dec 3 16:33:22.138, len: 77, hits: 1, buffhdr type: 1
[59] Dec 3 16:43:36.619, len: 77, hits: 1, buffhdr type: 1
[73] Dec 3 16:55:02.586, len: 77, hits: 1, buffhdr type: 1
Can you provide the hexdump?
keyword is in the same command.
we can inspect the packet and see what the interfaces doesn't like
[8] Dec 3 16:24:42.610, len: 77, hits: 1, buffhdr type: 1
Ingress Headers:
port_ifh: 0x1f8, sub_ifh: 0x0, bundle_ifh: 0x0
logical_port: 0x1b, pd_pkt_type: 4
FTMH:
pkt_size: 0x6c, tc: 1, tm_act_type: 0, ssp: 0x1b
PPH:
inlif: 0x0, vrf: 0xffff, rif: 0x615
FHEI:
trap_code: Rx_UNKNOWN_PACKET (63), trap_qual: 27
ab000002 0000cc8e 7169999f 60023d00 07000000 01000303 00000200 02210003
00060000 00000000 0400023c 00050002 d8050600 02000107 0006cc8e 7169999f
64000179 90010101 91010240 09000000 00000000 00000000 00000000 00000000
ok it seems the peer device is sending these packets
  • Destination: DEC-MOP-Remote-Console (ab:00:00:02:00:00)
  • Source: Cisco_69:99:9f (cc:8e:71:69:99:9f)
  • Type: DEC DNA Remote Console (0x6002)
please turn it off.. i belive it is "no mop enabled" under the peer interface
Good to know.  All of interfaces on this NCS 540 are v4 point-to-point.  None the less, I'll work on getting that disabled.
Great, thanks
