[ncs 5500] 4-byte ASN
Carlos A. Silva
Level 3
Level 3
I'm currently testing eBGP in an NCS5500. While a 2-byte ASN session worked without a problem, the 4-byte session did not (against Spirent TG). We get the following error messages:
nt=3071, memfailcount=0}}
RP/0/RP1/CPU0:Feb 28 18:10:31.462 : bgp[1050]: [default-rtr]: Received UPDATE from 10.0.3.5 (length incl. header = 96)
RP/0/RP0/CPU0:Feb 28 18:10:31.462 : bgp[1050]: [default-rtr]: NH-Validate-Create: addr=10.0.3.5/32, len=4, nlriafi=0, nbr=10.0.3.5, gwafi=0, gwlen=4, gwaddrlen=32::: nhout=0x0x7ffbb43a234c, validity=1, attrwdrflags=0x00000000
RP/0/RP0/CPU0:Feb 28 18:10:31.462 : bgp[1050]: [default-rtr]: Ignoring NEW_ASPATH attribute from 10.0.3.5 (a 4-byte AS capable peer)
RP/0/RP0/CPU0:Feb 28 18:10:31.462 : bgp[1050]: [default-rtr]: --bgp4_rcv_attributes--: END: nbr=10.0.3.5:: msg=0x0x2217ca8/96, updlen=77, attrbl=0x0x2217cbf/33, ipv4reachlen=40, msginpath=0x0x7ffbb9fb37c0, asloopcheck=1, attrwdrfl=0x00000000:: samecluster=0, local_as_prepended=0, attr_wdr_flags 0x00000000, myascount=0:: rcvdata=0x0x2217ce0/0, errptr=0x0x2217cd3/13
RP/0/RP0/CPU0:Feb 28 18:10:31.462 : bgp[1050]: [default-rtr] (ip4u): Received unreachables from 10.0.3.5: attrcode=0, attrwdrflags=0x00000000
RP/0/RP0/CPU0:Feb 28 18:10:31.462 : bgp[1050]: [default-rtr] (ip4u): UPDATE from 10.0.3.5 with attributes:
RP/0/RP1/CPU0:Feb 28 18:10:31.461 : bgp[1050]: [default-rtr]: --bgp4_rcv_attributes--: END: nbr=10.0.3.5:: msg=0x0x184f5d8/96, updlen=77, attrbl=0x0x184f5ef/33, ipv4reachlen=40, msginpath=0x0x7fa7761ad7c0, asloopcheck=1, attrwdrfl=0x00000000:: samecluster=0, local_as_prepended=0, attr_wdr_flags 0x00000000, myascount=0:: rcvdata=0x0x184f610/0, errptr=0x0x184f603/13
RP/0/RP1/CPU0:Feb 28 18:10:31.461 : bgp[1050]: [default-rtr] (ip4u): Received unreachables from 10.0.3.5: attrcode=0, attrwdrflags=0x00000000
RP/0/RP1/CPU0:Feb 28 18:10:31.461 : bgp[1050]: [default-rtr] (ip4u): UPDATE from 10.0.3.5 with attributes:
RP/0/RP1/CPU0:Feb 28 18:10:31.461 : bgp[1050]: [default-rtr] (ip4u): nexthop 10.0.3.5/32, origin i
RP/0/RP1/CPU0:Feb 28 18:10:31.461 : bgp[1050]: [default-rtr] (ip4u): UPDATE from 10.0.3.5, prefix 12.0.0.0/24 (path ID: none) DENIED due to:
RP/0/RP1/CPU0:Feb 28 18:10:31.461 : bgp[1050]: [default-rtr] (ip4u): malformed update 'treat-as-withdraw';
RP/0/RP0/CPU0:Feb 28 18:10:31.462 : bgp[1050]: [default-rtr]: aspath first AS is 1537212616, not 200000
RP/0/RP0/CPU0:Feb 28 18:10:31.462 : bgp[1050]: [default-rtr]: Invalid ASPATH segment received from 10.0.3.5
RP/0/RP0/CPU0:Feb 28 18:10:31.462 : bgp[1050]: [default-rtr]: !!!!!!!!!!!!!:: ERROR_HANDLING<<10.0.3.5>> :: errfl=0x00000200, attrfl=0x40, attrcode=2, attrlen=6:: errhenabled=1, action=4:: MSG=0x7ffb84000cd8 (fl=0x00000200, finalaction=4, elemcount=1):: msglindex=1, msgcount=2307
RP/0/RP0/CPU0:Feb 28 18:10:31.462 : bgp[1050]: [default-rtr]: UPDATE from 10.0.3.5 contains nh 10.0.3.5/32, gw_afi 0, flags 0x20000, nlri_afi 0
RP/0/RP1/CPU0:Feb 28 18:10:31.461 : bgp[1050]: [default-rtr] (ip4u): UPDATE from 10.0.3.5, prefix 12.0.1.0/24 (path ID: none) DENIED due to:
RP/0/RP1/CPU0:Feb 28 18:10:31.461 : bgp[1050]: [default-rtr] (ip4u): UPDATE from 10.0.3.5, prefix 12.0.2.0/24 (path ID: none) DENIED due to:
RP/0/RP1/CPU0:Feb 28 18:10:31.462 : bgp[1050]: [default-rtr] (ip4u): malformed update 'treat-as-withdraw';
RP/0/RP1/CPU0:Feb 28 18:10:31.462 : bgp[1050]: [default-rtr] (ip4u): UPDATE from 10.0.3.5, prefix 12.0.3.0/24 (path ID: none) DENIED due to:
The line in red I find particularly weird. The session does come up, but NCS5k does not accept incoming routes.
Any suggestions?
c.
11 Replies 11
mivens
What is the neighbour AS you have configured on the NCS-5500 and the Spirent?
If the first AS in the path doesn't match, it will be rejected unless you configure "enforce-first-as disable"
We tried the command and it didn't work.
The question is: why is the NCS getting that non-existent ASN in the aspath?
Hi Carlos,
we have the same issue on ASR9912 and 6.1.3.
Did you solve this issue and if yes, how?
Hi!
We didn't. We just used a router instead of the Spirent Traffic Generator and it worked.
c.
We have solved it using this command under neighbor configuration.
Great to know, just in case. We were working with an NCS5508, though.
hi carlos,
this: aspath first AS is 1537212616, not 200000 means that the as path attribute for the prefix is not what was expected for the update.
this is not a bug per-se but may be a mis configuration somewhere, this if you have a router bgp <something> with a neighbor <spirent> remote-as 200000 configured on the device under test.
BGP between ncs5500/asr9k/xrv and any xr device operates the same, there is no platform dependency here.
cheers!
xander
Hi do you have a solution for this?
i have the same problem :
Received unreachables from 172.16.2.20: attrcode=15, attrwdrflags=0x00000000
RP/0/RSP1/CPU0:Mar 13 01:01:19 : bgp[1067]: [default-rtr] (vpn4u): UPDATE from 172.16.2.20, prefix 2ASN:28114:28114:154.68.160.0/22 (path ID: none) withdrawn
smailmilak
Level 4
Level 4
This is a eBGP session and you have a incoming route policy with PASS for this neighbor?
You should also check this out:
The BGP Enhanced Attribute Error Handling feature prevents peersessionsfrom flapping due to a malformed
Update. The malformed Update is treat-as-withdraw and does not cause the BGP session to be reset. This
feature is enabled by default, but can be disabled.
The features are implemented in the following order:
1 Received Updates that contain user-specified path attributes are treat-as-withdraw (as long as the NLRI
can be parsed successfully). If there is an existing prefix in the BGP routing table, it will be removed. The
neighbor path-attribute treat-as-withdraw command configures this feature.
2 User-specified path attributes are discarded from received Updates, and the rest of the Update is processed
normally. The neighbor path-attribute discard command configures this feature.
3 Received Updates that are malformed are treat-as-withdraw. This feature is enabled by default; it can be
disabled by configuring the no bgp enhanced-error command
Sadly, none of those commands are available on 6.1.3 on an NCS5500.  i know the router configuration is fine, if it's expected to be the same as in an ASR9000, for example. Spirent looks fine.
Adam Vitkovsky
Level 3
Level 3
Hmmm seems like the message was not parsed correctly, and it messed up the AS-PATH attribute, it thinks the first AS is 1537212616, not 200000 and probably the expected length is not matching up either triggering the Enhanced Attribute Error Handling.
Most likely a bug in the code, so you might want to open up a TAC case on this.
adam
netconsultings.com
::carrier-class solutions for the telecommunications industry::
adam
