NCS5500 WANPHY
bgiorgadze
Hello everyone , I  try to enable  wanphy mode on  NCS55A2  controller move to preconfigure state. may have any ideas or solutions?
RP/0/RP0/CPU0:Nov 12 09:42:41.846 UTC: config[67800]: %MGBL-CONFIG-6-INT_UNRESOLVED : Some of the interface configuration was moved to pre configuration automatically as these interfaces do not exist or could not be mapped to any nodes
try both two tips of sfp's  SFP-10G-LR-S and SFP-10G-LR-S
controller preconfigure wanphy0/0/1/1
wanmode on
Output commands
RP/0/RP0/CPU0:NCS_55A2#show platform
Tue Nov 12 10:01:27.269 UTC
Node Type State Config state
0/0/1 NC55-MPA-12T-S OK
0/RP0/CPU0 NCS-55A2-MOD-SE-S(Active) IOS XR RUN NSHUT
0/RP0/NPU0 Slice UP
0/FT0 NC55-A2-FAN-FW OPERATIONAL NSHUT
0/FT1 NC55-A2-FAN-FW OPERATIONAL NSHUT
0/FT2 NC55-A2-FAN-FW OPERATIONAL NSHUT
0/FT3 NC55-A2-FAN-FW OPERATIONAL NSHUT
0/FT4 NC55-A2-FAN-FW OPERATIONAL NSHUT
0/FT5 NC55-A2-FAN-FW OPERATIONAL NSHUT
0/FT6 NC55-A2-FAN-FW OPERATIONAL NSHUT
0/FT7 NC55-A2-FAN-FW OPERATIONAL NSHUT
0/PM0 NC55-930W-DCFW OPERATIONAL NSHUT
0/PM1 NC55-930W-DCFW FAILED NSHUT
RP/0/RP0/CPU0:NCS_55A2#show install active summary
Tue Nov 12 10:01:30.558 UTC
Active Packages: 9
ncs5500-xr-6.6.25 version=6.6.25 [Boot image]
ncs5500-mgbl-3.0.0.0-r6625
ncs5500-li-1.0.0.0-r6625
ncs5500-isis-2.1.0.0-r6625
ncs5500-mcast-2.1.0.0-r6625
ncs5500-ospf-2.0.0.0-r6625
ncs5500-mpls-2.1.0.0-r6625
ncs5500-mpls-te-rsvp-3.1.0.0-r6625
ncs5500-k9sec-3.1.0.0-r6625
RP/0/RP0/CPU0:NCS_55A2#show inventory
Tue Nov 12 10:02:33.931 UTC
NAME: "0/0", DESCR: "NC55A2 MOD Scale Virtual Line Card"
PID: NCS-55A2-MOD-SE-S , VID: V01, SN: FOC231978CS
NAME: "0/0/1", DESCR: "NCS5500 12 SFP with 10G OTN, WAN PHY, MacSec, DWDM MPA"
PID: NC55-MPA-12T-S , VID: V01, SN: FOC224949QY
NAME: "TenGigE0/0/1/0", DESCR: "Cisco SFP+ 10G LR Pluggable Optics Module"
PID: SFP-10G-LR-S , VID: V01, SN: FNS231513Z8
NAME: "TenGigE0/0/1/1", DESCR: "Cisco SFP+ 10G LR Pluggable Optics Module"
PID: SFP-10G-LR , VID: V02, SN: PH5N901845
smilstea
I did some research on this and the initial release of the MPA did not support WANPHY (6.5.1).
Let me see if that is available in a release already or when it is scheduled.
Sam
smilstea
Seems that your sales engineer took the same path I did to get the answer and we got the same result. I will let him update you on the current status during your working hours.
Sam
