09-03-2015 03:12 AM
For some reason there isn't any dBm showing when you do a show controllers gigabitEthernet x/x/x/x phy on a satellite gig port in an ASR9K. All "normal" ports are showing dBm and if i log into the satellite and do a show satellite powerlevels port x you get the dBm value. Seems like someone forgot to add the conversion from Watt to dBm for satellite ports when executing the show controllers gig phy command. Im running 5.2.4 at the moment.
No dBm value
RP/0/RSP0/CPU0:asr9k#show controllers gigabitEthernet 1000/0/0/0 phy Thu Sep 3 10:39:37.871 CET Port: 0 Xcvr Type: SFP Vendor Name: CISCO-SUMITOMO CLEI Code: WMOTB8UAAA Part Number: 10-2294-01V01 Product Id: ONS-SI-100-LX10 Thresholds: Alarm High Warning High Warning Low Alarm Low Temperature: 105C 95C -45C -45C Voltage: 4000mV 3600mV 3000mV 2800mV Bias: 70mAmps 60mAmps 0mAmps 0mAmps Transmit Power: 316uW 199uW 25uW 15uW <--------Missing (dBm) Receive Power: 6553uW 6553uW 0uW 0uW <--------Missing (dBm) Temperature: 29 C Voltage: 3347 mV Bias: 4 mAmps Tx Power: 60 uW <-------Missing (dbm) Rx Power: 449 uW <------Missing (dbm)
when logged into satellite i can see dBm but i would like to see this without logging into the satellite.
LC:Satellite#show satellite powerlevels port 1 SFP Measurement Values for port:1 ------------------------------ Thresholds: Alarm High Warning High Warning Low Alarm Low Temperature: 105.0000C 95.0000C -45.0000C -45.0000C Voltage: 4000.0000uV 3600.0000uV 3000.0000uV 2800.0000uV Tx Bias: 70.0000mA 60.0000mA 0.0000mA 0.0000mA Tx Power: 0.3161mW (-5.0003dBm) 0.1994mW (-7.0005dBm) 0.0250mW (-16.0032dBm) 0.0157mW (-18.0134dBm) Rx Power: 6.5534mW (8.1647dBm) 6.5534mW (8.1647dBm) 0.0000mW (0.0000dBm) 0.0000mW (0.0000dBm) Temperature: 28.9257C Laser Bias: 4.1299mA Voltage: 3347.3999uV Tx Power: 0.0603mW (-12.1896dBm) Tx State: Normal Rx Power: 0.4349mW (-3.6151dBm) Rx State: Normal
Regards Peter
Solved! Go to Solution.
09-03-2015 03:31 AM
Hi Peter,
indeed, this was missed out in earlier releases. Starting with release 5.3.0 power levels on satellite access ports are displayed in dBm.
Aleksandar
09-03-2015 03:31 AM
Hi Peter,
Aleksandar
09-03-2015 03:37 AM
Hi Aleksandar
Thanks for that speedy reply. The IOS-XR supportforum rocks!
One more question about optical levels and the satellite. Seems to be some delay on the levels that are reported when doing the show controller xxxx phy command. Is there some polling interval going on in the background when it comes to fetching optical levels from the satellite?
/Regards Peter
09-03-2015 08:08 AM
hi peter,
yeah some commands are "cached" this is to improve scale. Many commands can access the hw directly (eg show controller np counters) especially if they are single shot ones, but some of them need to be cached in order to maintain speedy cli access, fast results but yeah in that case there is a lag between instant and read value...
The other reason why this is needed is that many CPU's or NP's are much faster now adays than what the memory can realistically handle. hence memory banking and more intelligent memory controllers. For instance stats memory (we use QDR) has some specifics in that regard taht we have to deal with, hence we use caching and banking in order to maintain that performance we need.
If you like to read more about caching and all check this article that describes teh snmp methodology for caching
https://supportforums.cisco.com/document/132706/asr9000xr-understanding-snmp-and-troubleshooting
cheers!
xander
09-03-2015 11:47 PM
Hi Alexander.
Thanks for the info. Will check that link out.
Regards Peter
