Not able to configure pseudowire under bridge-group
kvishu170692
I am configuring pseudowire under l2vpn bridge-domain, but when I am commiting the configuration, getting error as below
RP/0/0/CPU0:iosxrv-1(config-l2vpn-bg-bd-pw)#show configuration failed
Mon May  8 11:31:24.062 UTC
!! SEMANTIC ERRORS: This configuration was rejected by
!! the system due to semantic errors. The individual
!! errors with each failed configuration command can be
!! found below.
l2vpn
 bridge group Test
  bridge-domain cisco
   neighbor 192.168.0.2 pw-id 12345
!!% Not supported: Platform does not support access PW
Please help to resolve the issue..
Vishwajeet
18 Replies 18
Aleksandar Vidakovic
IOS XRv is control plane only. It doesn't support L2VPN. If you need L2VPN in virtual environment, you can use XRv9000.
Hi Aleksandar,
Thanks for your reply..
I am able to configure l2vpn with xconnect but l2vpn with bridge-group/domain not possible.
xconnect is a simple connect of two pipes, while bridge-domain requires many more features which XRv doesn't support.
Thank You for support.
Will you help me for how to use XRv9000 platform in VIRL?
With a lot of help from my colleagues, I hope I have all the info that you need for this.
You can install XRv9000 from the VIRL installation itself in UWM (User Workspace Manager). From there, the procedure is
  • 'VIRL Server' item in the left menu
  • 'VIRL Software' menu item
  • Select the 'Install' box for the IOS XRv 9000 image from the 'Cisco VM image upgrades' section / table
  • Click 'Start Installation' at the top of that page
This will require Internet connectivity to the Salt infrastructure (which is needed for VIRL users anyway, so that should not be an issue). It will take a couple of minutes to download that file. After that, you should be able to use XRv 9000 images.
Note, however, that the current XRv 9000 image requires 8GB of memory and 2 vCPUs per node vs 3GB of memory and 1 vCPU for XRv classic. In addition, there is a known defect with the current version of XRv 9000 that prevents the VM to use the management network. This will be resolved in XR release 6.2.2, but the good news is that you can already use the 6.2.2 EFT image.
  • To give you access to the 6.2.2 EFT image, please send me your CCO user ID through a private message. The steps to send a private message:
  • Copy the name of the person you want to send the message to
  • Go to your profile
  • Go to Messages
  • Click "New Message"
  • Paste the recipient name
  • write the message and send it
Hope this helps,
/Aleksandar
Thanks for information!
I have installed the iosxrv9000 image & configured the VPLS, but it is showing not supported.
RP/0/RP0/CPU0:iosxrv9000-1(config)#l2vpn
RP/0/RP0/CPU0:iosxrv9000-1(config-l2vpn)#bridge group STC
RP/0/RP0/CPU0:iosxrv9000-1(config-l2vpn-bg)#bridge-domain STCTest
RP/0/RP0/CPU0:iosxrv9000-1(config-l2vpn-bg-bd)#vfi STC
RP/0/RP0/CPU0:iosxrv9000-1(config-l2vpn-bg-bd-vfi)#exit
RP/0/RP0/CPU0:iosxrv9000-1(config-l2vpn-bg-bd)#neighbor 192.168.0.1 pw-id 12345
RP/0/RP0/CPU0:iosxrv9000-1(config-l2vpn-bg-bd-pw)#commit
Wed May 17 09:18:53.184 UTC
% Failed to commit one or more configuration items during a pseudo-atomic operation. All changes made have been reverted. Please issue 'show configuration failed [inheritance]' from this session to view the errors
RP/0/RP0/CPU0:iosxrv9000-1(config-l2vpn-bg-bd-pw)#show configuration failed
Wed May 17 09:18:59.432 UTC
!! found below.
l2vpn
 bridge group STC
!!% Operation not supported: Platform does not support access PW
end
Indeed, I forgot to check the roadmap before replying. Support for L2VPN on XRv9000 will come in XR release 6.3. If you are using XRv9000 only in the lab, we can share soon an early code drop. Please contact me via private message for more details.
/Aleksandar
Thanks for your support!!
I have installed iosxrv9000 image & configured VPLS, but it is also showing not supported
!! found below.
l2vpn
 bridge group STC
end
i'm using XRv9000 but same issue ,, Cisco IOS XRv9k platform
Same issue on IOS-XRv9000
RP/0/RP0/CPU0:bms-west(config-l2vpn-bg-bd-evi)#do sh ver
Wed Apr 22 16:22:04.502 UTC
Cisco IOS XR Software, Version 7.0.1
Copyright (c) 2013-2019 by Cisco Systems, Inc.
Build Information:
Built By : ahoang
Built On : Thu Aug 29 16:11:57 PDT 2019
Built Host : iox-ucs-030
Workspace : /auto/srcarchive15/prod/7.0.1/xrv9k/ws
Version : 7.0.1
cisco IOS-XRv 9000 () processor
System uptime is 2 days 1 hour 40 minutes
allow to insert the configuration, but does not allow to commit
RP/0/RP0/CPU0:bms-west(config-l2vpn-bg-bd-evi)#sh conf failed inheritance
Wed Apr 22 16:30:52.918 UTC
!! found below.
l2vpn
bridge group evpn
bridge-domain evpn1
interface GigabitEthernet0/0/0/3
!!% Invalid argument: VPLS Bridge domains not supported on this platform
end
l2vpn
bridge group P2P
bridge-domain VPN_HQ
mtu 9000
neighbor 10.7.104.1 pw-id 5005
neighbor 10.7.104.2 pw-id 5005
end
Tue Jul 28 09:41:29.652 UTC
Cisco IOS XR Software, Version 6.6.3
Build Information:
Built By : hlo
Built On : Fri Dec 13 16:42:11 PST 2019
Built Host : iox-ucs-033
Workspace : /auto/srcarchive15/prod/6.6.3/xrv9k/ws
Version : 6.6.3
System uptime is 1 week 6 days 23 hours 42 minutes
AhmedDimah
HI,
I'm using now IOS XRv 9K version 7.0.2 and still same issue here.
RP/0/RP0/CPU0:R1(config-l2vpn-bg-bd-ac)#commit show-error
Mon Jan 18 10:47:32.832 UTC
!! found below.
l2vpn
bridge group abc
bridge-domain abc
interface GigabitEthernet0/0/0/0
end
Hello
Unfortunately it seems that no L2VPN of any sort is going to be supported by the Cisco IOS-XRV platform, in order to run some tests I had to refer to commercial lab services with real lab gear.
That is correct. There are virtualization issues with l2 protocols, not just an XR issue.
Sam
