packet filtering on BGP communities
william jackson
Hi all
I want to achieve the following scenario:
I have a BGP feed that gives me routes with community X.
I have an input ACL on an interface.
I want to be able to say:
if src or dst of packet = any route with community x then drop
I can do this with FBF in junos, can I do this on IOS-XR?
Hi William,
I think you can use technique similar to RTBH :
http://www.cisco.com/en/US/prod/collateral/iosswrel/ps6537/ps6586/ps6642/prod_white_paper0900aecd80313fac.pdf
by using rpl to set the next-hop to a /32 address statically routed to NULL.
For source address match, you combine this with RPF.
Hope it helps,
Serge.
serge123
Thanks serge, but this is not what I want.
The route-policy only apply at the routing level, what I want is to packet filter based on routes having certain communities.
Hi William,
Hope it helps,
Serge.
Thanks serge
thats just what I need.
