Power supply Issue in Cisco ASR 9010
Sushant Kaliraj
Somebody please explain below:
RP/0/RSP0/CPU0:xxxx#admin show environment power-supply
Wed Feb 12 22:17:10.864
R/S/I   Modules Sensor          Watts           Status
Power Shelves Type: DC
Total Power Capacity:                              0W
Usable Power Capacity:                             0W
Supply Failure Protected Capacity:                 0W
Feed Failure Protected Capacity:                   0W
Worst Case Power Used:                          1490W
Slot                                                      Max Watts
0/RSP0/CPU0                                                     250  (default)
0/RSP1/CPU0                                                     250  (default)
0/FT0/SP                                                        495  (default)
0/FT1/SP                                                        495  (default)
Worst Case Power Deficit:               1490W
Supply Protected Capacity Available:    Not Protected
Feed Protected Capacity Available:      Not Protected
I  have connected power in Cisco ASR 9010 ( only one power module is  powered up). The ASR9k box is up and functioning ( although it is not  taking all  line-cards due to power issue). I am not seeing the power  module in above output and even Total power capacity is zero? Is it a  hardware issue?
0 Replies 0
