CRS 4.3.0 ebgp-multihop
dfauluchi
Hi guys,
I upgraded a CRS1-8 from 3.9.2 to 4.3.0 using turboboot.
In 3.9.2 there were 2 ebgp-multihop neighbors configured (and established) with ttl=2.
When the router started with 4.3.0 I copied the same config, but I had to configure ttl=3 to make those 2 neighbors come up.
I didn't find bugs related to ebg-multihop ttl in this version. Anyway, I used CSM1.0 to select SMUs and activated all recommended SMUs but one (they don' t have enough space in disk0:).
The one that's missing is: Umbrella DDTS for kimono fixes - CSCue45856
Bug description and details couldn't say less...I can't figure out what kimono fixes mean. Any ideas?
Thanks in advance.
Diego.
Rivalino Tamaela
Regarding ebgp-multihop, this looks like CSCum1306 (ebgp-multihop configuration inconsistency seen on customer network), which is duplicate of CSCue06523.
CSCue06523 is fixed in 4.3.1, and 5.1.0.
thanks,
rivalino
Rivalino Tamaela
Hi Diego,
kimono is codename for plim card 6-10GE-WLO-FLEX. CSCue45856 contains fixes related with this card. If you don't have that card, you can skip this ddts.
HTH,
Riv
Rivalino Tamaela
thanks,
rivalino
