pseudowire shortname
Peter L
I know that you implemented some shortcuts in 5.1.3 for bundle-ether and TenGigabitEthernet. Any plans to implement the same function for pw-ether? Really annoying to work with pw-ether at the moment, when it gets displayed as PExxxxx in some views but you must use pw-ether xxxxx to show/configure the interface
RP/0/RSP0/CPU0:9k#show interfaces  description | in PE
Wed Nov 19 13:47:47.177 CET
PE10001            up          up          test-xxxxx
RP/0/RSP0/CPU0:9k#show interfaces PE10001
% Invalid input detected at '^' marker.
RP/0/RSP0/CPU0:9k#show interfaces pw-ether10001
Wed Nov 19 13:49:35.505 CET
PW-Ether10001 is up, line protocol is up
  Interface state transitions: 11
  Hardware is PWHE Ethernet Interface, address is a80c.0d71.4215
  Description: test-xxxxx
  Internet address is 1.1.1.1/31
  MTU 1514 bytes, BW 10000 Kbit (Max: 10000 Kbit)
     reliability 255/255, txload 0/255, rxload 0/255
  Encapsulation ARPA,  loopback not set,
  ARP type ARPA, ARP timeout 04:00:00
    L2Overhead: 0
    Generic-Interface-List: pw-he
  Last input 00:00:00, output 00:00:00
  30 second input rate 1000 bits/sec, 4 packets/sec
  30 second output rate 1000 bits/sec, 4 packets/sec
     3830527 packets input, 989740649 bytes, 4521 total input drops
     0 drops for unrecognized upper-level protocol
     Received 0 broadcast packets, 4501 multicast packets
     3861314 packets output, 921387947 bytes, 0 total output drops
     Output 0 broadcast packets, 78706 multicast packets
RP/0/RSP0/CPU0:9k(config)#interface pe10001
RP/0/RSP0/CPU0:9k(config)#interface pw-ether 10001
RP/0/RSP0/CPU0:9k(config-if)#
/Regards Peter
Peter L
"bump"
Peter, we're working on it. Stay tuned.
Any update on this? Running 5.2.4 now and still no pwhe shortnames.
hi peter,
this is tracked with ddts: CSCur91179   need shortcut name for pseudowire ether to PE for show CLIs
I see it is not integrated yet, let me get that going right away. apologies for the delay here!
cheers!
xander
