Redistribute static under router bgp zzzzz vrf xxxxx does not work
I was working on a maintenance window.  moving some customers to our  new MPLS network  PE router NCS540 SOFTWARE 7.6.2.
When I move 192.168.70.0/24 to the new mpls network   I was able to ping it from everywhere. however a static routed network I was not able to reach even though I could see the route advertized everywhere in the network
int bvi 100
vrf CORE_14288
ipv4 address 192.168.70.1 255.255.255.0
router bgp 11749
vrf CORE_14288
rd auto
address-family ipv4 unicast
redistribute connected
redistribute static
router static
vrf CORE_14288
192.168.10.0/27 192.168.70.2
After doing some digging I found that the redistribute static was not  allowing the traffic to pass thru even though I could see it advertized from every PE in the network.
If I hardcode it like shown below, it works.
router bgp xxxx
vrf CORE_14288
I opened a ticket with cisco just to make sure this is not a bug, but I'm curious to see if anybody has experience the same behaviour.
Hi @DanielGutierrez615 ,
The first label (26065) is a per vrf label and is allocated by the network statement. The second one (26085) is a per prefix/per CE label and is generated by the redistribute static statement.
It looks like there might be an issue when the per prefix/per CE is used, possibly because of the BVI interface. You could validate that by changing the label mode under the VRF and verify that it works with the redistribute static as well.
router bgp xxx
vrf CORE_14288
label mode per-vrf
This will cause the label to be allocated per-vrf regardless if you use the network statement or redistribute static statement.
46 Replies 46
Did you use rpl abd allow all prefix includes static route
MHM
Harold Ritter
I am not sure I understand what you did to fix the issue, as the following command is invalid under BGP:
router bgp xxx
vrf CORE_14288
Can you please give us more specific information.
Sorry I didn't paste it propertly..
NOTE: THE IP ADDRESSED I'M USING HERE ARE NOT THR REAL ONES
what I did to fix the issue  is:
instead of having
router bgp 11749
vrf CORE_14288
rd auto
redistribute static    <<<----removed this
I removed the "redistribute static" and add   network 192.168.1.0/24
like this.
router bgp 11749
vrf CORE_14288
rd auto
network 192.168.1.0/24  <<<---- added
I also tried using an RLP
prefix-set ALLOW_STATIC_ROUTES_SET
  192.168.1.0/24
end-set
route-policy ALLOW_STATIC_ROUTES
if destination in ALLOW_STATIC_ROUTES_SET then
pass
else
drop
endif
end-policy
BUT it will I gues same results. No reachbility to the routed static network
Both the "redistribute static" and the network statement should work.
You say that when you use the "redistribute static" the route was learned on the remote sites, but that you could not ping addresses within that subnet, right?
That is correct Harold. I'm beginning to think that this might be a bug missed on the NCS540-iosxr-k9-7.6.2 software release. I open a ticket with cisco to confirm my theory.
That definitely sounds like a bug. Please keep up posted on what TAC says.
when you redistrubte you can not ping
when you use prefix without redistribute you can ping
if above correct
show bgp
check the next hop
it next-hop issue
specially  if you use ibgp
MHM
you see the route where you use redistribute static or  using the network command.
Here is THE OUTPUT wheN is not working with redistribute static
RP/0/RP0/CPU0:SCTLAB-NCS540-02#show bgp vpnv4 unicast vrf CORE_14288
Route Distinguisher: 10.0.24.203:1 (default for vrf CORE_14288)
*>i0.0.0.0/0 10.0.24.2 100 0 14288 174 i
* i 10.0.24.4 100 0 14288 3356 i
*>i66.90.3.108/30 10.0.24.4 0 100 0 ?
*>i66.90.3.144/30 10.0.24.2 0 100 0 ?
*>i207.190.12.96/27 10.0.24.35 0 100 0 ?
*>i216.53.129.228/30 10.0.24.35 0 100 0 ?
*>i216.53.129.236/30 10.0.24.37 0 100 0 ?
*>i216.53.178.168/29 10.0.24.35 0 100 0 ?
*> 216.97.200.64/29 0.0.0.0 0 32768 ?
*>i216.97.200.88/29 10.0.24.34 0 100 0 ?
*> 216.97.207.0/27 216.97.200.66 0 32768 ?
Processed 10 prefixes, 11 paths
Here is THE OUTPUT wheN is working with the network statement.
*> 216.97.207.0/27 216.97.200.66 0 32768 i
Sorry I forgot to mention the network I'm trying to reach is  216.97.207.0/27
Could you please provide the following command from SCTLAB-NCS540-02 when it works and when it doesn't.
show bgp vpnv4 unicast vrf CORE_14288 labels
It would be good to check if the label received on remote PE is properly installed on the PE originating it.
here
This is when it works
RP/0/RP0/CPU0:SCTLAB-NCS540-02#show bgp vpnv4 unicast vrf CORE_14288 labels
Status codes: s suppressed, d damped, h history, * valid, > best
i - internal, r RIB-failure, S stale, N Nexthop-discard
Origin codes: i - IGP, e - EGP, ? - incomplete
Network Next Hop Rcvd Label Local Label
*>i0.0.0.0/0 10.0.24.2 24009 nolabel
* i 10.0.24.4 26063 nolabel
*>i66.90.3.108/30 10.0.24.4 26061 nolabel
*>i66.90.3.144/30 10.0.24.2 24008 nolabel
*>i207.190.12.96/27 10.0.24.35 26080 nolabel
*>i216.53.129.228/30 10.0.24.35 26080 nolabel
*>i216.53.129.236/30 10.0.24.37 26058 nolabel
*>i216.53.178.168/29 10.0.24.35 26080 nolabel
*> 216.97.200.64/29 0.0.0.0 nolabel 26065
*>i216.97.200.88/29 10.0.24.34 26106 nolabel
*> 216.97.207.0/27 216.97.200.66 nolabel 26065
here is the output where it does not works
*> 216.97.207.0/27 216.97.200.66 nolabel 26066
RP/0/0/CPU0:XR1# show mpls forwarding <<- share this for both case
thanks
MHM
RP/0/RP0/CPU0:SCTLAB-NCS540-02#show mpls forwarding  vrf CORE_14288 detail
Wed Jun 12 12:46:26.319 EDT
Local  Outgoing    Prefix             Outgoing     Next Hop        Bytes
Label  Label       or ID              Interface                    Switched
26065  Aggregate   CORE_14288: Per-VRF Aggr[V]   \
                                      CORE_14288                   2181874
     Updated: Jun 12 06:55:45.033
     Label Stack (Top -> Bottom): { }
     MAC/Encaps: 0/0, MTU: 0
     Packets Switched: 37964
debug  detail
Wed Jun 12 12:45:01.681 EDT
                                      CORE_14288                   2180110
     Updated: Jun 12 06:55:45.034
     Packets Switched: 37929
Also from the peering route pespective
it works
RP/0/RP0/CPU0:MTD-RTR-PE1-01#show bgp vpnv4 unicast vrf CORE_14288 labels
Route Distinguisher: 10.0.24.4:4 (default for vrf CORE_14288)
*> 0.0.0.0/0 66.90.3.109 nolabel 26063
*> 66.90.3.108/30 0.0.0.0 nolabel 26061
*>i216.97.200.64/29 10.0.24.203 26065 nolabel
*>i216.97.207.0/27 10.0.24.203 26065 nolabel <<<<<
does not work
*>i216.97.207.0/27 10.0.24.203 26085 nolabel
