RPL Nesting
Paul Lachance
Question : Nested RPL – What is the Sequence for the DATA -
                So from the RPL at the final end policy TO_OUTSIDE we nest the two RPL that preform two separate functions
One looks for a prefix the other a AS path.
The Question when the first rpl is executed to check prefix filter it will find two and pass them to the advertise neighbour in this scenario
When it pass the second apply it will find two matching AS numbers and pass it to the neighbour.
Does the RPL on the second apply take data in from the first ?
                Or since the 10.10.30.0 is dropped in the first apply will it be tested on the second apply
And if there is a match in both but one rpl changes characteristics of the match what is the hierarchy , Does the last apply make the final change ?
DATA IN :
198.162.10.0      AS555
172.16.20.0        AS666
10.10.30.0          AS777
prefix-set PREFIXES_OUT
198.162.0.0/16 le 24,
172.16.0.0/16 le 24
end-set
as-path-set AS_FILTER
  ios-regex '_555$',
  ios-regex '_666$',
 end-set
route-policy PREFIXES_ALLOWED
  if destination in PREFIXES_OUT then
    pass
  else
    drop
  endif
end-policy
route-policy ASPATH_ALLOWED
  if as-path in AS_FILTER then
    pass
  else
    drop
  endif
end-policy
Policy to be applied to the BGP peering point
route-policy TO_OUTSIDE
  Apply PREFIXES_ALLOWED
  Apply ASPATH_ALLOWED
  end-policy
xthuijs
That is a great question Paul!
the answer is that RPL will always execute on "unmodified" or original data.
for instance:
route-policy first
  if origin is igp then
    set local-preference 123
  endif
end-policy
route-policy second
  if local-preference is 123 then
    set med 321
  endif
end-policy
route-policy umbrella
  apply first
  apply second
end-policy
now when a prefix comes in subject to this RPL umbrella:
  1. the MED will only be set if the local-pref IS already 123 when it came in.
  2. If it is received as LP 100 and origin igp, then we will SET LP 123, but we will NOT set MED.
this is done for sound reasons to make sure that RPL could not loop inside.
xander
