100Gb Interface MTU
Some one could help me, I want to know MTU value for the interface of the ASR SR 100Gb, because when traffic goes through interface a problem  of performance (slow traffic) appears. I think it's a MTU problem because 100Gb inteface is a high-density interface and MTU is crucial in these cases.
Regards.
14 Replies 14
Peter L
Max configurable MTU on the ASR9K is 9216. This will give you 9220 as max allowed frame size. If you haven't configured anything in the CLI the default MTU is 1514.
Regards Peter
Hi Peter,
I try MTU 9216 but traffic still have a slow performance, when I do a rollback the traffic have a normal performance, that interface is a bundle, 4X10Gb.
Regards.
Can you clarify "slow performance" a bit more?`Don't you get expected performance or what is wrong? Have you checked the 100gb interface in both ends for drops/errors?
/Peter
Hi Peter,
slow connection to internet, when a pass the traffic trought de 100Gb interface, I do not see any drop and error on the interface, but when  I pass trough de 4x10Gb  interface (Bundle interface) the connection to internet work perfect, That's why I think it is a problem concerning MTU
Hi Fredy,
your interface counters are clean, all your L1 stats are solid also, and you dont have any fragmentation issue as far as I can tell:
    Input pkts 1024-1518 bytes  = 4069777
    Input pkts 1519-Max bytes   = 0
I am suspecting that you are testing the circuit with too few flows.
As Sam hinted on these 2 cards have a FIA (fabric interface asic) that use VOQ's (virtual output queues) that are shaped at 13G and in some releases with a specific configuration setting can be set to 21G (or somewhere there).
A 100G interface is represented by 10 of those VOQ's, a single 10G interface is represented by 1 VOQ and ten 1G interfaces share a VOQ together also.
VOQ's are used to prevent head of line blocking and also provide for priority propagation (since each VOQ has 4 priority VQI's = virtual queuing instance).
yeah lots of TLA's (three letter acronyms) and if you like to read more on this check out this set of info.
To identify where the drops are coming from and propose the right mitigation check this:
show controller np counters [np] location [slot loc of LC]
run that twice to get some decent rate counters with a 1-5 second interval.
this will identify if we have to punt packets to the CPU, or whether we are losing something there.
the next thing to check is the:
show controller fabric fia stats location, this will help us identify the VOQ queue depth, and (tail) drops that happen in that asic.
I suspect you see voq depth building and tail drops which would identify the fact that your flow variety is not good enough.
you need minimally 10 10G flows (and preferably more flows) in order to take the power of this card.
Flows are loadbalanced over the available VOQ's. How the loadbalancing works is part of the deck set I ref'd above also.
The Tomahawk set of linecards can do single flow 100G.
To make sure, the 1x100 or 2x100 have no flaw or anything, but were bound by the technology available at the time to develop FIA's to support rates like this.
And also the fact that the PHY (optical piece) is connecting via multiple SGMII lanes to the MAC FPD (part of the NPU). In short you need flow variety :)
regards
xander
Hi Alexander,
Can help this output?
RP/0/RSP1/CPU0:Router#show controllers np counters np0 location 0/7/CPU0
Thu Jun 25 00:13:23.914 UTC
                Node: 0/7/CPU0:
Show global stats counters for NP0, revision v2
Read 15 non-zero NP counters:
Offset  Counter                                         FrameValue   Rate (pps)
  16  MDF_TX_LC_CPU                                           4787           3
  21  MDF_TX_FABRIC                                             54           0
  33  PARSE_FAB_RECEIVE_CNT                                     54           0
  37  PARSE_INTR_RECEIVE_CNT                                838756         513
  41  PARSE_INJ_RECEIVE_CNT                                     27           0
  49  PARSE_TM_LOOP_RECEIVE_CNT                               7885           5
  67  PRS_HEALTH_MON                                          7885           5
  76  INTR_FRAME_TYPE_7                                       4760           3
 107  PARSE_RSP_INJ_DIAGS_CNT                                   54           0
 121  PARSE_LC_INJ_DIAGS_CNT                                    27           0
 291  DBG_RSV_EP_L_RSV_ING_PUNT                               4841           3
 790  DIAGS                                                     27           0
 902  PUNT_STATISTICS                                         4756           3
 904  PUNT_DIAGS_RSP_ACT                                        27           0
 906  PUNT_DIAGS_RSP_STBY                                       27           0
RP/0/RSP1/CPU0:Router#show controllers np counters np1 location 0/7/CPU0
Thu Jun 25 00:13:29.899 UTC
                Node: 0/7/CPU0:
Show global stats counters for NP1, revision v2
Read 14 non-zero NP counters:
  16  MDF_TX_LC_CPU                                           4888           3
  21  MDF_TX_FABRIC                                          43594          27
  29  PARSE_INTER_NP_RECEIVE_CNT                                54           0
  37  PARSE_INTR_RECEIVE_CNT                                841905         513
  41  PARSE_INJ_RECEIVE_CNT                                  43567          27
  49  PARSE_TM_LOOP_RECEIVE_CNT                               7914           5
  67  PRS_HEALTH_MON                                          7914           5
  76  INTR_FRAME_TYPE_7                                       4861           3
  93  PARSE_ING_INTER_NP_THRU_TRAFFIC                           54           0
 119  PARSE_LC_INJ_FAB_CNT                                   43540          27
 291  DBG_RSV_EP_L_RSV_ING_PUNT                               4888           3
 790  DIAGS                                                     27           0
 902  PUNT_STATISTICS                                         4861           3
RP/0/RSP1/CPU0:Router#show controller np counters all location 0/7/CPU0
Thu Jun 25 00:13:35.750 UTC
                Node: 0/7/CPU0:
  16  MDF_TX_LC_CPU                                           4822           3
  37  PARSE_INTR_RECEIVE_CNT                                844826         513
  49  PARSE_TM_LOOP_RECEIVE_CNT                               7942           5
  67  PRS_HEALTH_MON                                          7942           5
  76  INTR_FRAME_TYPE_7                                       4795           3
 291  DBG_RSV_EP_L_RSV_ING_PUNT                               4876           3
 790  DIAGS                                                     27           0
 902  PUNT_STATISTICS                                         4795           3
  16  MDF_TX_LC_CPU                                           4905           3
  21  MDF_TX_FABRIC                                          44660         182
  37  PARSE_INTR_RECEIVE_CNT                                844910         513
  41  PARSE_INJ_RECEIVE_CNT                                  44633         182
  76  INTR_FRAME_TYPE_7                                       4878           3
 119  PARSE_LC_INJ_FAB_CNT                                   44606         182
 291  DBG_RSV_EP_L_RSV_ING_PUNT                               4905           3
 790  DIAGS                                                     27           0
 902  PUNT_STATISTICS                                         4878           3
Show global stats counters for NP2, revision v2
Read 23 non-zero NP counters:
  16  MDF_TX_LC_CPU                                           5718           3
  17  MDF_TX_WIRE                                        178044293      108094
  33  PARSE_FAB_RECEIVE_CNT                              178044310      108094
  37  PARSE_INTR_RECEIVE_CNT                                845429         513
  41  PARSE_INJ_RECEIVE_CNT                                    422           0
  49  PARSE_TM_LOOP_RECEIVE_CNT                               7941           5
  67  PRS_HEALTH_MON                                          7941           5
  76  INTR_FRAME_TYPE_7                                       5404           3
 105  PARSE_RSP_INJ_FAB_CNT                                  60330          37
 108  PARSE_EGR_INJ_PKT_TYP_UNKNOWN                             62           0
 109  PARSE_EGR_INJ_PKT_TYP_IPV4                             59978          36
 113  PARSE_EGR_INJ_PKT_TYP_IPV4_PREROUTE                      290           0
 120  PARSE_LC_INJ_PORT_CNT                                    395           0
 291  DBG_RSV_EP_L_RSV_ING_PUNT                               5485           3
 790  DIAGS                                                     27           0
 850  PUNT_ADJ                                                 225           0
 902  PUNT_STATISTICS                                         5404           3
 --More--            904  PUNT_DIAGS_RSP_ACT                                        27           0
 908  NETIO_RP_TO_LC_CPU_PUNT                                   62           0
Show global stats counters for NP3, revision v2
Read 44 non-zero NP counters:
  16  MDF_TX_LC_CPU                                         125087          76
  21  MDF_TX_FABRIC                                      135616121       82335
  37  PARSE_INTR_RECEIVE_CNT                                846104         514
  41  PARSE_INJ_RECEIVE_CNT                                     28           0
  45  PARSE_ENET_RECEIVE_CNT                             135666746       82366
  53  PARSE_TOP_LOOP_RECEIVE_CNT                         134367098       81577
  62  PARSE_ING_DISCARD                                          2           0
  76  INTR_FRAME_TYPE_7                                       6077           4
  88  DBG_PRS_EP_L_PRS_PL_ABF                             67120525       40750
 119  PARSE_LC_INJ_FAB_CNT                                       1           0
 136  PARSE_DROP_IN_UIDB_DOWN                                    2           0
 228  PARSE_UDLD                                                 7           0
 286  DBG_RSV_EP_L_RSV_ING_L3_IFIB                            5960           4
 287  DBG_RSV_EP_L_RSV_ING_L3_IFIB_MATCH                      5960           4
 288  DBG_RSV_EP_L_RSV_ING_L3_IFIB_PUNT_LOCAL                  462           0
 290  DBG_RSV_EP_L_RSV_ING_L3_RSLTS_MATCH                     5960           4
 291  DBG_RSV_EP_L_RSV_ING_PUNT                             130587          79
 292  RSV_OPEN_NETWORK_SERVICE_TRIGGER_SVC                67178609       40786
 306  DBG_RSV_EP_L_RSV_ABF_PASS1                          67120871       40750
 307  DBG_RSV_EP_L_RSV_ABF_PASS2                          67120875       40750
 317  RSV_OPEN_NETWORK_SERVICE_PHASE                      67178660       40786
 518  RSV_SNF_SAMPLE_PKT                                     68426          42
 519  RSV_SNF_IPV4                                           68426          42
 520  RSV_SNF_ING_PUNT                                       68426          42
 774  CDP                                                        7           0
 776  ARP                                                        2           0
 790  DIAGS                                                     27           0
 832  PUNT_NO_MATCH                                             12           0
 840  IPV4_TTL_ERROR                                         38704          23
 850  PUNT_ADJ                                                  34           0
 854  PUNT_ACL_DENY                                          11245           7
 902  PUNT_STATISTICS                                         6077           4
 936  PUNT_NETFLOW                                           68426          42
 944  PUNT_IPV4_ADJ_NULL_RTE                                    94           0
1195  MDF_PIPE_LPBK                                      134371030       81579
1198  MDF_PIPE_LPBK_BUFFER_PREFETCH                        8764307        5321
1201  MDF_OPEN_NETWORK_SERVICE_SEND_TO_CONTROLLER          67180194       40786
1250  MODIFY_PUNT_NF_MSG                                     68427          42
1251  MODIFY_PUNT_NF_IPV4                                    68427          42
RP/0/RSP1/CPU0:Router#show controller fabric fia stats location 0/7/CPU0
Thu Jun 25 00:15:22.515 UTC
 ********** FIA-0 **********
Category: count-0
                         From Unicast Xbar[0]                       19
                         From Unicast Xbar[1]                       10
                         From Unicast Xbar[2]                        0
                         From Unicast Xbar[3]                        0
                       From MultiCast Xbar[0]                       58
                       From MultiCast Xbar[1]                        0
                       From MultiCast Xbar[2]                        0
                       From MultiCast Xbar[3]                        0
                           To Unicast Xbar[0]                    33486
                           To Unicast Xbar[1]                    33377
                           To Unicast Xbar[2]                        0
                           To Unicast Xbar[3]                        0
                         To MultiCast Xbar[0]                       29
                         To MultiCast Xbar[1]                        0
                         To MultiCast Xbar[2]                        0
                         To MultiCast Xbar[3]                        0
                         To Line Interface[0]                       58
                         To Line Interface[1]                        0
                       From Line Interface[0]                    66874
                       From Line Interface[1]                       18
                                Ingress drop:                        0
                                 Egress drop:                        0
                                 Total drop:                         0
 ********** FIA-1 **********
Category: count-1
                         From Unicast Xbar[0]                        0
                         From Unicast Xbar[1]                        0
                       From MultiCast Xbar[0]                        0
                           To Unicast Xbar[0]                       10
                           To Unicast Xbar[1]                        8
                         To MultiCast Xbar[0]                        0
                         To Line Interface[0]                        0
                       From Line Interface[0]                       14
                       From Line Interface[1]                        4
                                Ingress drop:                        0
                                 Egress drop:                        0
                                 Total drop:                         0
 ********** FIA-2 **********
Category: count-2
                         From Unicast Xbar[0]                 64243977
                         From Unicast Xbar[1]                 64254170
                           To Unicast Xbar[0]                 49671225
                           To Unicast Xbar[1]                 49581179
                         To MultiCast Xbar[0]                      418
                         To Line Interface[0]                 66296903
To Line Interface[1]                 65678959
                       From Line Interface[0]                 50644579
                       From Line Interface[1]                 50897180
                                Ingress drop:                        0
                                 Egress drop:                        0
                                 Total drop:                         0
 ********** FIA-3 **********
Category: count-3
                         From Unicast Xbar[0]                 78726490
                         From Unicast Xbar[1]                 51725727
                           To Unicast Xbar[0]                 49583048
                           To Unicast Xbar[1]                 49473216
                         To Line Interface[0]                 65874524
                         To Line Interface[1]                 68220434
                       From Line Interface[0]                 50355891
                       From Line Interface[1]                 50900451
                                Ingress drop:                        0
                                 Egress drop:                        0
                                 Total drop:                         0
yeah that helps,
you seem to be ABF (access list based forwarding) a lot of packets coming in on the interface back out of it again!? is that right?
may want to remove ABF for a second and see if it is forwarded the way you expect...
xander
Alexander,
I can not remove the ABF because the ASR has an ISM module and doing CGN using ABF.
I use ABF to divert traffic to the ISM.
Regards.
Hi Fredy,
NP counters don't show any drops. There are also no drops on the fabric. The traffic rate on the HundredGigE0/7/0/0 is far less than 13Gbps, so the VQI shaper doesn't come into the picture here even if you had all the traffic calculated to the same hash value. Can you explain a more comprehensively what did you exactly mean by "slow traffic"? Why are you suspecting an issue with MTU (the controller counters don't show any frames received or sent with size above 1518 bytes)?
regards,
/Aleksandar
Hi Aleksandar,
Here the topology
Topology
Users who use the services of 3G, FTTH, GPON, feel slow Internet connection. do not load youtube videos, web pages open slowly.
 When the traffic passing back through the interface Bundle 2x10Gb (no shutdown) everything works normally. So I thought it was something of MTU, but I think even that is not the problem.
Regards.
Hi all,
I want to tell you that I had solve the problem using a bundle interface then associated with the physical interface 100Gb in this way started to run smoothly.
It is strange to work this way, but it works.
:-D
Regards.
Which 100GbE card are you using?
How many flows do you have?
The 1 and 2x100 cards on 9K are limited to around 13G per flow.
Sam
Hi smilstea,
The card is A9K-2x100GE-TR.
I don't understand about 13G per flow, sorry, could you explain me please?
Here some output, I hope can help:
RP/0/RSP1/CPU0:Router#show interface hundredGigE 0/7/0/0
Thu Jun 25 00:10:25.604 UTC
HundredGigE0/7/0/0 is up, line protocol is up
  Interface state transitions: 15
  Hardware is HundredGigE, address is d46d.5006.88a6 (bia d46d.5006.88a6)
  Layer 1 Transport Mode is LAN
  Description:  HundredGigE0/0/0/0
  Internet address is X.X.X.X/YY
  MTU 1514 bytes, BW 100000000 Kbit (Max: 100000000 Kbit)
     reliability 255/255, txload 9/255, rxload 1/255
  Encapsulation ARPA,
  Full-duplex, 100000Mb/s, link type is force-up
  output flow control is off, input flow control is off
  loopback not set,
  ARP type ARPA, ARP timeout 04:00:00
  Last input 00:00:00, output 00:00:00
  Last clearing of "show interface" counters 00:24:32
  30 second input rate 499062000 bits/sec, 313498 packets/sec
  30 second output rate 3591623000 bits/sec, 436841 packets/sec
     16640982 packets input, 3387017120 bytes, 2 total input drops
     0 drops for unrecognized upper-level protocol
     Received 2 broadcast packets, 21 multicast packets
              0 runts, 0 giants, 0 throttles, 0 parity
     0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored, 0 abort
     23302163 packets output, 23497866749 bytes, 0 total output drops
     Output 77 broadcast packets, 43 multicast packets
     0 output errors, 0 underruns, 0 applique, 0 resets
     3 carrier transitions
RP/0/RSP1/CPU0:Router#  show controller hundredGigE 0/7/0/0 stat    all
Thu Jun 25 00:11:15.640 UTC
Operational data for interface HundredGigE0/7/0/0:
State:
    Administrative state: enabled
    Operational state: Up
    LED state: Green On
Phy:
    Media type: MMF fiber over 10 lane optics (short reach)
    Optics:
        Vendor: CISCO
        Part number: FTLC8281RCNM-C3
        Serial number: FNS18410BB4
MAC address information:
    Operational address: d46d.5006.88a6
    Burnt-in address: d46d.5006.88a6
    No unicast addresses in filter
    No multicast addresses in filter
Autonegotiation disabled.
Operational values:
    Speed: 100Gbps
    Duplex: Full Duplex
    Flowcontrol: None
    Loopback: None (or external)
    MTU: 1518
    MRU: 1518
    Inter-packet gap: standard (12)
    BER monitoring:
        Signal Degrade: 10e-0 (no-alarm)
        Signal Fail: 10e-0 (report-alarm)
BERT status for HundredGigE0/7/0/0:
BERT State                      :       DISABLED
Test Pattern                    :       None test pattern
Time Remaining                  :       0
Time Interval                   :       0
Statistics for interface HundredGigE0/7/0/0 (cached values):
Ingress:
    Input total bytes           = 10283938954
    Input good bytes            = 10283938954
    Input total packets         = 48313182
    Input 802.1Q frames         = 0
    Input pause frames          = 0
    Input pkts 64 bytes         = 8784740
    Input pkts 65-127 bytes     = 30709635
    Input pkts 128-255 bytes    = 2092478
    Input pkts 256-511 bytes    = 1443001
    Input pkts 512-1023 bytes   = 1213551
    Input good pkts             = 48313182
    Input unicast pkts          = 48313150
    Input multicast pkts        = 30
    Input broadcast pkts        = 2
    Input drop overrun          = 0
    Input drop abort            = 0
    Input drop invalid VLAN     = 0
    Input drop invalid DMAC     = 0
    Input drop invalid encap    = 0
    Input drop other            = 0
    Input error giant           = 0
    Input error runt            = 0
    Input error jabbers         = 0
    Input error fragments       = 0
    Input error CRC             = 0
    Input error collisions      = 0
    Input error symbol          = 0
    Input error other           = 0
    Input MIB giant             = 0
    Input MIB jabber            = 0
    Input MIB CRC               = 0
Egress:
    Output total bytes          = 69519958774
    Output good bytes           = 69519958398
    Output total packets        = 64032394
    Output 802.1Q frames        = 0
    Output pause frames         = 0
    Output pkts 64 bytes        = 2793452
    Output pkts 65-127 bytes    = 11092252
    Output pkts 128-255 bytes   = 2383515
    Output pkts 256-511 bytes   = 1354220
    Output pkts 512-1023 bytes  = 1491783
    Output pkts 1024-1518 bytes = 44917172
    Output pkts 1519-Max bytes  = 0
    Output good pkts            = 64032394
    Output unicast pkts         = 64032213
    Output multicast pkts       = 60
    Output broadcast pkts       = 122
    Output drop underrun        = 0
    Output drop abort           = 0
    Output drop other           = 0
    Output error other          = 0
Management information for interface HundredGigE0/7/0/0:
Bay number: 0
Port number: 0
Interface handle: 0x120000c0
Config:
    Auto-negotiation: Configuration not supported (Off)
    Carrier delay (up): Not configured
    Carrier delay (down): Not configured
    Speed: Configuration not supported (100Gbps)
    Duplex: Configuration not supported (Full Duplex)
    Flow Control: Not configured (None)
    IPG: Not configured (standard (12))
    Loopback: Not configured (None)
    MTU: Not configured
    Bandwidth: Not configured
    BER-SD Threshold: Not configured (10e-0)
    BER-SD Report: Not configured (Disabled)
    BER-SF Threshold: Not configured (10e-0)
    BER-SF Report: Not configured (Enabled)
    BER-SF Signal Remote Failure: Not configured (Disabled)
Driver constraints:
    Min MTU: 64 bytes
    Max MTU: 9216 bytes
    Max speed: 100Gbps
    Interface type: HundredGigE
    Management interface: No
    Promiscuous mode: Yes
    Default carrier delay up (auto-neg on): 0 ms
    Default carrier delay down (auto-neg on): 0 ms
    Default carrier delay up (auto-neg off): 0 ms
    Default carrier delay down (auto-neg off): 0 ms
    Allowed config mask: 0xe7b
    BER:
        SD (min - max): (10e-6 - 10e-9)
        SD default: 10e-0
        SF (min - max): (10e-6 - 10e-9)
        SF default: 10e-0
Cached driver state:
    MTU: 1514 bytes
    Burnt-in MAC address: d46d.5006.88a6
Operational carrier delay:
    Carrier delay (up): 0 ms
    Carrier delay (down): 0 ms
Not a member of a bundle interface.
Satellite uplink settings:
    Not in satellite uplink (ICL) mode.
Port FSM state:
    Port is enabled, link is up
Complete FSM state:
    Admin up
    Client admin up
    Client admin tx not disabled
    Port enabled
    Port tx enabled
    Hardware link up
IDB interface state information:
    IDB client admin up
    IDB client tx admin up
    IDB error disable not set
0 Unicast MAC Addresses:
0 Multicast MAC Addresses:
 none
Port Number         : 0
Bay Number          : 0
Ifinst              : 0
Ifinst Subport      : 0
Board Type          : 0x00280251
Port Type           : 100GE
Transport mode      : LAN
BIA MAC addr        : d46d.5006.88a6
Oper. MAC addr      : d46d.5006.88a6
Egress MAC addr     : d46d.5006.88a6
Port Available      : true
Status polling is   : enabled
Status events are   : enabled
I/F Handle          : 0x120000c0
Cfg Link Enabled    : tx/rx enabled
H/W Tx Enable       : yes
MTU                 : 1518
H/W Speed           : 100 Gbps
H/W Duplex          : Full
H/W Loopback Type   : None
H/W FlowCtrl Type   : None
H/W AutoNeg Enable  : Off
H/W Link Defects    : (0x00000000)  none
H/W Raw Link Defects : (0x00000000)  none
Link Up             : yes
Link Led Status     : Link up   -- Green/Amber
Pluggable Present   : yes
Pluggable Type      : CFP-100G-SR10
Pluggable PID       : CFP-100G-SR10
Pluggable Compl.    : Compliant
Pluggable Type Supp.: Supported
Pluggable PID Supp. : Supported
NP->Mac Lane Sync   : 0x001fffff
PHY->Mac Lane Sync  : 0x000fffff
Mac Version         : 0x00000027
 --More--
Rx        64B66B      Lane        Sync        PCS         Virt  PCS
Service   Block       Marker      Header      Lane        Lane  Lane
Lane      Lock        Sync        Err Cnt     BIP Errors  Error Mapping
0         Locked      Locked      0           0           Clean 1
1         Locked      Locked      0           0           Clean 0
2         Locked      Locked      0           0           Clean 3
3         Locked      Locked      0           0           Clean 2
4         Locked      Locked      0           0           Clean 5
5         Locked      Locked      0           0           Clean 4
6         Locked      Locked      0           0           Clean 7
7         Locked      Locked      0           0           Clean 6
8         Locked      Locked      0           0           Clean 9
9         Locked      Locked      0           0           Clean 8
10        Locked      Locked      0           0           Clean 10
11        Locked      Locked      0           0           Clean 11
12        Locked      Locked      0           0           Clean 13
13        Locked      Locked      0           0           Clean 12
14        Locked      Locked      0           0           Clean 15
15        Locked      Locked      0           0           Clean 14
16        Locked      Locked      0           0           Clean 16
17        Locked      Locked      0           0           Clean 17
18        Locked      Locked      0           0           Clean 18
19        Locked      Locked      0           0           Clean 19
CFP EEPROM port: 0
  Xcvr Type: CFP
  Ext Type: 16W, Host Lane n:n, CLEI,
  Connector Type: MPO
  Ethernet Application Codes: 100GE-SR10,
  Number of Lanes: Network 10, Host 10
  Max Bit Rate: Network Lane 10.4Gbit/s, Host Lane 10.4Gbit/s
 --More--             Link Reaches: SM Fiber 0KM, MM Fiber: 100M, Copper: 0M
  Device Tech1: VCSEL, DML,
  Device Tech2: No WL, Uncool Xmtr, Xmtr not tunable, No VOA, PIN detector, No EDC,
  Encoding: NRZ, Non-PSK,
  Vendor Name: CISCO
  Vendor OUI: 00.90.65
  Vendor Part Number: FTLC8281RCNM-C3
  Vendor Serial Number: FNS18410BB4
  Date Code (yyyymmdd): 20141006, Lot Code 00
  DDM Type: RX Avg Power, TX OMA,
  Module DDM: Power Supply Voltage, Temperature,
  Per Lane DDM: Laser Bias,
  Enhanced Options: Host Lpbk, Host Emp Ctrl,
 MSA Data (CFP NVR 1 Table - addr 0x8000-0x807F)
0x0000: 0e 61 09 03 00 00 00 00 : 00 aa 4a 34 34 00 0a 00
0x0010: 0a 01 83 40 86 60 02 8a : 00 04 40 4f 15 3c 32 46
0x0020: 00 43 49 53 43 4f 20 20 : 20 20 20 20 20 20 20 20
0x0030: 20 00 90 65 46 54 4c 43 : 38 32 38 31 52 43 4e 4d
0x0040: 2d 43 33 20 46 4e 53 31 : 38 34 31 30 42 42 34 20
0x0050: 20 20 20 20 32 30 31 34 : 31 30 30 36 30 30 49 50
0x0060: 55 49 42 52 34 52 41 41 : 0e 0e 02 00 01 07 0c 03
0x0070: 02 a0 04 01 01 00 64 01 : 00 00 00 00 00 00 00 72
        CLEI Code: IPUIBR4RAA
        Part Number: 10-2787-01    (ver.: V01 )
        Product ID: CFP-100G-SR10
 Vendor Specific Data (Vendor Cisco NVR 1 Table - address 0x8400-0x847F)
0x0100: 00 00 00 00 00 00 00 00 : 00 00 00 00 00 00 00 00
0x0110: 43 49 53 43 4f 20 20 20 : 20 20 20 20 20 20 20 20
0x0120: 43 46 50 2d 31 30 30 47 : 2d 53 52 31 30 20 20 20
0x0130: 56 30 31 20 07 46 4e 53 : 31 38 34 31 30 42 42 34
0x0140: 31 30 2d 32 37 38 37 2d : 30 31 20 20 41 30 20 20
0x0150: 00 00 00 00 00 00 00 00 : 00 00 00 00 00 00 00 00
0x0160: 00 00 00 00 00 00 00 00 : 00 00 00 00 00 00 00 00
0x0170: 00 00 00 00 00 00 00 00 : 00 00 00 00 00 00 00 a2
 --More--
        Module
        Thresholds:                    Alarm High         Warning High          Warning Low            Alarm Low
              Temperature:            +74.000 C             +70.000 C              +0.000 C              -4.000 C
                  Voltage:           3.665 Volt            3.465 Volt            3.135 Volt            2.935 Volt
        Temperature: +39.519 C
        Voltage: 3.319 Volt
        Lanes
                     Bias:         15.000 mAmps          14.000 mAmps           5.000 mAmps           4.000 mAmps
           Transmit Power:  1.99520 mW (2.99986 dBm)   0.79430 mW (-1.00015 dBm)   0.17370 mW (-7.60200 dBm)   0.06910 mW (-11.60522 dBm)
            Receive Power:  4.36510 mW (6.39994 dBm)   1.73780 mW (2.40000 dBm)   0.11220 mW (-9.50007 dBm)   0.04460 mW (-13.50665 dBm)
                Lane            Temp             Bias                   Tx Power                   Rx Power
                   0             N/A     10.184 mAmps                        N/A                        N/A
                   1             N/A      9.622 mAmps                        N/A                        N/A
                   2             N/A      9.944 mAmps                        N/A                        N/A
                   3             N/A     10.184 mAmps                        N/A                        N/A
                   4             N/A     10.184 mAmps                        N/A                        N/A
                   5             N/A     10.184 mAmps                        N/A                        N/A
                   6             N/A     10.184 mAmps                        N/A                        N/A
                   7             N/A      9.944 mAmps                        N/A                        N/A
                   8             N/A      9.944 mAmps                        N/A                        N/A
                   9             N/A     10.104 mAmps                        N/A                        N/A
 Threshold Data (CFP NVR 2 Table - address 0x8080-0x80ff)
0x0080: 4a 00 46 00 00 00 fc 00 : 8f 2a 87 5a 7a 76 72 a6
0x0090: 00 00 00 00 00 00 00 00 : 00 00 00 00 00 00 00 00
0x00a0: 00 00 00 00 00 00 00 00 : 1d 4c 1b 58 09 c4 07 d0
0x00b0: 4d f0 1f 07 06 c9 02 b3 : 4a 00 46 00 00 00 fc 00
0x00c0: aa 83 43 e2 04 62 01 be : 00 00 00 00 00 00 00 00
0x00d0: 00 00 00 00 00 00 00 00 : 00 00 00 00 00 00 00 00
0x00e0: 00 00 00 00 00 00 00 00 : 00 00 00 00 00 00 00 00
 --More--           0x00f0: 00 00 00 00 00 00 00 00 : 00 00 00 00 00 00 00 98
  OPTICS:
   Rx LOS Fault       : No
   Tx Fault           : No
  MAC:
   Rx Local Fault     : No
   Rx Remote Fault    : No
MAC registers:
0x0010 registers.clock_status                  : 0x000003ff
0x0014 registers.soft_reset                    : 0x00000000
0x0030 registers.revision_register             : 0x00000027
0x0034 registers.software_status               : 0x00000000
0x0100 registers.hseib_buffer_configuration    : 0x00000010
0x0104 registers.rx_hsec_configuration0        : 0x00001c09
0x0158 registers.oobfc_configuration           : 0x00000007
0x0200 registers.tx_hsec_configuration0        : 0x00000003
0x0208 registers.tx_hsec_max_packet_len        : 0x000005ee
0x0230 registers.tx_buffer_pause_src_address1  : 0x00000000
0x0234 registers.tx_buffer_pause_src_address0  : 0xd46d5006
0x0400 registers.iipc_serdes0_configuration0   : 0x00000db3
0x0404 registers.iipc_serdes0_configuration1   : 0x00000000
0x04a8 registers.hsec_serdes0_configuration0   : 0x000004a8
0x04ac registers.hsec_serdes0_configuration1   : 0x00000000
0x1010 interupts.rx_hsec_err_intr              : 0x00000000
0x1018 interupts.rx_hsec_err_mask              : 0x0001fffc
0x1020 interupts.rx_buffer_err_intr            : 0x00000000
0x1040 interupts.tx_hsec_err_intr              : 0x00000000
0x1050 interupts.tx_buffer_err_intr            : 0x00000000
0x1080 interupts.system_monitor_intr           : 0x00000000
0x1090 interupts.seu_intr                      : 0x00000000
0x1110 interupts.rx_hsec_bip7_0_status_intr    : 0x00000001
0x1120 interupts.device_intr                   : 0x00000000
0x1124 interupts.device_enable                 : 0x00000001
0x2000 stats.rx_hsec_status                    : 0x00000004
0x2004 stats.rx_hsec_framing_err               : 0x000fffff
0x200c stats.rx_hsec_synced_err                : 0x000fffff
0x2410 stats.rx_interlaken_status              : 0x00000201
0x2418 stats.rx_interlaken_synced_err          : 0x00000000
0x242c stats.rx_interlaken_framing_err         : 0x00000000
0x2434 stats.rx_interlaken_crc32_err           : 0x00000000
AFP registers:
0x0000 cfp_reg_info_                           : 0x002c0f41
0x0004 reg_init_stat_                          : 0x00000000
 --More--           0x0008 reset_                                  : 0x00000000
0x000c int_stat_                               : 0x00000000
0x0010 int_en_                                 : 0x00000050
0x0014 int_frc_                                : 0x00000000
0x0018 stat_                                   : 0x00000007
0x001c ctrl_                                   : 0x000040c5
PHY registers:
0x0000 nlp-reg1                                : 0x00000000
0x0001 nlp-reg2                                : 0x00000001
0x0002 nlp-reg3                                : 0x00000002
