RSP-4G Crash upgrade 6.1.4
Philippe P
i tried to upgrade RSP-4G from 5.3.4 to 6.1.4
i follow instructions until activation :
after install activate router crash
after reset i received this message
Selecting ROMMON Image... B
DDR in Interleaved mode
POST 1 : PASSED : code 0 : DDR2 Memory Quick Test
CPU Reset Reason = 0x000d
POST 2 : PASSED : code 0 : FPGA Flash Image CRC Checks
Loading Field Programmable Devices:
FPGA 0-B PROGRAMMED  : image: 0xff500028 - 0xff576cca, et: 118ms
FPGA 1-B PROGRAMMED  : image: 0xff400028 - 0xff4d1034, et: 206ms
FPGA 2-B PROGRAMMED  : image: 0xff100028 - 0xff276358, et: 369ms
FPGA 3-B PROGRAMMED  : image: 0xff000028 - 0xff0454a8, et: 69ms
System Bootstrap, Version 1.06(20120210:003513) [ASR9K ROMMON],
Copyright (c) 1994-2012 by Cisco Systems, Inc.
Compiled Thu 09-Feb-12 16:35 by saurabja
  CPUCtrl:  1.17  [00000001/00000011]
  ClkCtrl:  1.23  [00000001/00000017]
  IntCtrl:  1.15  [00000001/0000000f]
     Punt:  1.5   [00000001/00000005]
      CBC:  1.3
      BID: 0x0006
PPC 8641D (partnum 0x8004), Revision 03.00, (Core Version 02.02)
M8641 CLKIN:   66 Mhz
 Core Clock: 1333 Mhz
  MPX Clock:  533 Mhz
  LBC Clock:   33 Mhz
POST 3 : PASSED : code 0 : Slot ID/Board Type Validity
PCI-E1: Ready as Root Complex
PCI-E2: Ready as Root Complex
set_chassis_type: chassis_type=0xef02fb found=TRUE
ASR9K (8641D PPC) platform with 4096 Mb of main memory
program load complete, entry point: 0x100000, size: 0x2ac20
MBI Candidate = disk0:asr9k-os-mbi-6.1.4/0x100000/mbiasr9k-rp.vm
    CARD_SLOT_NUMBER: 0
        CPU_INSTANCE: 1
MBI Validation starts ...
Mgt LAN 0 interface is selected
tsec_init_hw: configuring FE (port 2) for: Auto Speed, Auto Duplex
tsec_init_interface: hardware initialization completed
Interface link changed state to UP.
Interface link state up.
MBI validation sending request.
HIT CTRL-C to abort
No MBI confirmation received from dSC
AUTOBOOT: Boot string = disk0:asr9k-os-mbi-6.1.4/0x100000/mbiasr9k-rp.vm,1;
AUTOBOOT: autobootstate=0, autobootcount=0, cmd=boot disk0:asr9k-os-mbi-6.1.4/0x100000/mbiasr9k-rp.vm
MBI size from header = 21979816,Bootflash resident MBI filesize = 21979816
program load complete, entry point: 0x204184, size: 0x14f53a8
Attempting to start second CPU
Config = SMP, Running = SMP
Board type: 0x00100302
Card Capability = 0xffffffff
BSP: Board type : RO-RSP2
Processor family/kernel mismatch (2/4)
Crash[0,0] at init_cpu line 220.
i saw that it's possible to have X64 versions of IOS XR so
afterwards i treied in rommon to reactivate old IOSXR
rommon B2 > boot disk0:asr9k-os-mbi-5.3.4/0x100000/mbiasr9k-rp.vm
MBI size from header = 21782464,Bootflash resident MBI filesize = 21782464
program load complete, entry point: 0x2040c8, size: 0x14c50c0
tracelogger: starting tracing in background ring mode
tracelogger running with args: -startring -F 1 -F 2
              Restricted Rights Legend
Use, duplication, or disclosure by the Government is
subject to restrictions as set forth in subparagraph
(c) of the Commercial Computer Software - Restricted
Rights clause at FAR sec. 52.227-19 and subparagraph
(c) (1) (ii) of the Rights in Technical Data and Computer
Software clause at DFARS sec. 252.227-7013.
           cisco Systems, Inc.
           170 West Tasman Drive
           San Jose, California 95134-1706
Cisco IOS XR Software for the Cisco XR ASR9K, Version 5.3.4
Copyright (c) 2016 by Cisco Systems, Inc.
Jan 16 15:30:20.110: Install Setup: Booting with software activated by previous install operation
Jan 16 15:31:04.887: Install Setup: This node was booted with an incorrect MBI version (/bootflash/disk0/asr9k-os-mbi-5.3.4/0x100000/mbiasr9k-rp.vm) and will now reset to boot with the correct MBI (/bootflash/disk0/asr9k-os-mbi-6.1.4/0x100000/mbiasr9k-rp.vm)
Spawning instdir_show_ltrace -r  failed. : No such file or directory
Spawning instdir_show_ltrace -Z -r failed. : No such file or directory
Spawning inst_rds_show_ltrace -r  failed. : No such file or directory
reboot internal start: cause code 72 cause dSC booted with incorrect MBI
reboot_internal timeout 30 is gracef[0x34b473ba6] Record Reboot History, reboot cause = 0x4000048, descr = Cause: dSC booted with incorrect MBI                                          Process: instsetup                                                              Traceback: 50002eb8 4cb66rebooting
FPGA 0-B PROGRAMMED  : image: 0xff500028 - 0xff576cca, et: 117ms
      CBC:  1.3
      BID: 0x0006
M8641 CLKIN:   66 Mhz
  MPX Clock:  533 Mhz
  LBC Clock:   33 Mhz
but it failed again
For the moment, it was impossible for me to replace the Old versions
please let me know if you have an idea
PS : if needed i also have RSP with current 5.3.4 Version up and running
regards
Aleksandar Vidakovic
RSP-4G and RSP-8G are not supported in XR release 6.1. Optimal release for these RSPs is 5.3.4. If you already have another chassis with RSP-4G or RSP-8G running 5.3.4, best to take this RSP that fails to boot and insert it as standby into that other chassis. The RSP will sync the installation from the active.
64-bit IOS XR is supported on Tomahawk generation line cards and RSP880/RP2.
Thanks a lot for your feedback Aleksandar.
Just to be sure,i start ASR with good RSP, when up and running,i add the second  one ( hot-plug ) in order to have standby ?  and wait for sync
thanks in advance
That's correct. If one RSP is fully up and running, the one you insert into the other RSP slot will sync fully with the active one.
