SNMP Problem on CRS1 ios xr4.1.2
budilasmono
Dear all,
I got a problem on CRS4.1.2, we already upgrade it from 3.9.2 and then cacti server receive log that can reach SNMP on CRS1.
When using 3.9.2, cacti has no problem, and then on 4.1.2 cacti only able to generate report on some interface, and other interface are blank (partially).
The configuration is :
snmp-server engineID local 800000090300001A302B0F00
snmp-server view cutdown at excluded
snmp-server view cutdown iso included
snmp-server view cutdown ip.21 excluded
snmp-server view cutdown snmpUsmMIB excluded
snmp-server view cutdown snmpVacmMIB excluded
snmp-server view cutdown snmpCommunityMIB excluded
snmp-server view cutdown ipNetToMediaEntry.1 excluded
snmp-server view cutdown ipNetToMediaEntry.3 excluded
snmp-server view cutdown ipNetToMediaEntry.4 excluded
snmp-server community xxxx.xxxx view cutdown RO
snmp-server location Jakarta
  Node 0/RP0/CPU0 [HRP] [SDR: Owner]
    Boot Device: disk0:
    Boot Image: /disk0/hfr-os-mbi-4.1.2/mbihfr-rp.vm
    Active Packages:
      disk0:hfr-mini-px-4.1.2
      disk0:hfr-doc-px-4.1.2
      disk0:hfr-cgn-px-4.1.2
      disk0:hfr-mgbl-px-4.1.2
      disk0:hfr-fpd-px-4.1.2
      disk0:hfr-diags-px-4.1.2
I already install MGBL for SNMP function on IOS XR also.
Please help.
Budi L
budilasmono
Hi All,
Its solved, i've delete the snmp configuration and change the community string. And its works.
The existing community string is like : "S4mPl35tR1ng", and then i change it to "samplestring", and its works.
Thanks a lot,
Budi L
