Standby RP not detected in CRS-1 after XR upgrade 3.6 to 3.8
netops044
I am planning to upgrade CRS-1 from existing 3.6 to 4.2. Since I cant do it directly to 4.2, I upgraded to interim XR version 3.8. I have done everything as explained in the URL "http://www.cisco.com/web/Cisco_IOS_XR_Software/index.html". I also upgraded all FPD as explained in "IOS-XR Firmware upgrade guide". But after I upgraded the XR, standby RP is not showing as "Ready" in RP redundancy. Moreover when I do show platform, standby RP is "Present" but the type is displayed as "Unknown".
What could be the cause of this.
RP/0/RP0/CPU0:CRS-I(admin)#sh platform
Thu Aug 16 12:52:44.388 IST
Node            Type            PLIM            State           Config State
0/1/SP          MSC(SP)         N/A             IOS XR RUN      PWR,NSHUT,MON
0/1/CPU0        MSC             Jacket Card     IOS XR RUN      PWR,NSHUT,MON
0/1/0           MSC(SPA)        8XOC3/OC12-POS  OK              PWR,NSHUT,MON
0/1/5           MSC(SPA)        5X1GE           OK              PWR,NSHUT,MON
0/RP0/CPU0      RP(Active)      N/A             IOS XR RUN      PWR,NSHUT,MON
0/RP1/CPU0      UNKNOWN         N/A             PRESENT         PWR,NSHUT,MON
0/SM0/SP        FC/S(SP)        N/A             IOS XR RUN      PWR,NSHUT,MON
0/SM1/SP        FC/S(SP)        N/A             IOS XR RUN      PWR,NSHUT,MON
0/SM2/SP        FC/S(SP)        N/A             IOS XR RUN      PWR,NSHUT,MON
0/SM3/SP        FC/S(SP)        N/A             IOS XR RUN      PWR,NSHUT,MON
RP/0/RP0/CPU0:CRS-I(admin)#sh diag 0/RP1/CPU0
Thu Aug 16 12:57:30.031 IST
CARD 0/RP1/* : Unknown Card Type
Data Not Available
NODE 0/RP1/CPU0 : Unknown Node Type
Data Not Available
Please help.
thanks in advance,
Arun
Alexei Kiritchenko
Hello Arun,
We'd need to connect to the console of the standby RP to get its boot sequence in order to understand what is happening with it.
/A
smilstea
In which part of the upgrade did you lose the standby RP? Before or after upgrading the FPD and ROMMON? Also can you confirm that the standby was up when you upgraded the FPD and ROMMON? Are you getting any error messages on your console about the standby RP? It could be that the ROMMON version is too low and the card can not boot up at which point you would see error messages stating that the ROMMON revision is too low.
If that is not the issue then I would second Alexei and see what the standby RP does on bootup.
Sam
Sorry for not updating this. It seemed to be a bug "CSCti27164 RP kept resetting due to WDT during monlib and slow  disk". Workaround was to get into the console of RP, disable watchdog timeout and boot the RP. Once it is booted format the bootflash and reload the RP.
thanks,
Arun
