Thousands of Netio drops
wblackcenic
Using the command "show drops all ongoing location [LOCATION]", we are seeing hundreds of thousands of Netio drops for multiple interfaces between the command being run approximately 30 seconds apart.  From my understanding, Netio is effectively software switching in which the packet got punted to the LC CPU for some sort of processing.  My question is whether there is a way to determine what is being punted and why there are so many drops.
Thanks.
xthuijs
hi wblackcenic, yup there is!
follow this guide:
https://supportforums.cisco.com/document/59721/asr9000xr-troubleshooting-packet-drops-and-understanding-np-drop-counters
and or check cisco live id 2904 from orlando, sanfran and sandiego for more details about packet troubleshooting.
simply:
show controller np counters npX loc Y
and look for RSV_PUNT or PUNT_ type counters to see what is punted,
we canalso make captures of those packets on a per punt reason.
common case is access-list with deny resulting in copy to control plane for icmp unreach gneeration.
cheers
xander
Thanks, Xander.  I'll check out the Cisco Live presentation for more assistance.  From what I can tell, it looks like a lot of the punts may be Netflow related.
Thanks again.
very much possible wblack!
if that is causing soo many drops in netio, the sampling rate may be too agressive, although the lpts (punt policer) would rate limit the netflow punts to a max of 200kpps per LC.
cheers!
xander
