06-08-2016 05:57 PM
We’ve seen instances where after router reload intermittently 100G LCs may stay down and not come up to IOS XR RUN state, the LC may be in BRINGDOWN state, or the following syslog maybe seen in the syslog after failed boot up.
envmon[209]: %PLATFORM-ENVMON-3-ALARM_RAISED : Raise alarm from CBC in slot 0/10/CPU0, alarm code CBC_ALRM_PWR_SEQ_FAILED Reason: OUTPUT VOLTAGE FAULT Bus:0x2 Addresss:0xbc Chan:0x4 STATUS_VOUT 0x10
This impacts 100GEx4, 100GEx8 LC’s.
An OIR at times can fix the problem, though the more prudent method to avoid this, is install SMU: CSCuz52900.
SMUs are available for the following releases:
5.3.1, 5.3.2 & 5.3.3.
It's mandatory that the SMU is installed if 100GE Linecards are present in the chassis.
In the chance that the issue is experienced, the following command must be tried to recover the LC if an OIR is not successful:
“run pwrseq program 0/X/CPU0 0 0x2”
Eddie.
11-16-2016 10:23 PM
we have a very similar problem with a Trident LC A9K-8T-L.
We did an upgrade from 5.3.3 to 5.3.4 and this LC could not boot and it's now in BRINGDOWN state.
Reinsert did not help and we can't reload it with "admin reload location" and "
I have tried your command: "run
Error: command is not available for this card!
It's probably for TH LC only.
I found this log:
envmon[209]: %PLATFORM-ENVMON-3-ALARM_INDICATION : Raise alarm from CBC in slot 0/0/CPU0, alarm code CBC_ALRM_PWR_SEQ_FAILED
RP/0/RSP0/CPU0:Nov 17 06:55:11.572 : shelfmgr[409]: %PLATFORM-SHELFMGR-3-MIXED_MEMORY_POWERED : Node 0/0/CPU0 is powered, system running mixed line card memory mode
RP/0/RSP0/CPU0:Nov 17 06:55:11.572 : shelfmgr[409]: %PLATFORM-SHELFMGR-3-MIXED_MEMORY_ALARM : System enters mixed line card memory mode
RP/0/RSP0/CPU0:Nov 17 06:56:28.037 : shelfmgr[409]: %PLATFORM-SHELFMGR-3-SHUTDOWN_RESET : Node 0/0/CPU0 is reset due to admin shut/no shut request
RP/0/RSP0/CPU0:Nov 17 06:57:02.170 : shelfmgr[409]: %PLATFORM-SHELFMGR-3-SHUTDOWN_RESET : Node 0/0/CPU0 is reset due to admin shut/no shut request
RP/0/RSP0/CPU0:Nov 17 06:57:10.198 : envmon[209]: %PLATFORM-ENVMON-3-ALARM_INDICATION : Raise alarm from CBC in slot 0/0/CPU0, alarm code CBC_ALRM_PWR_SEQ_FAILED
RP/0/RSP0/CPU0:Nov 17 07:02:15.832 : shelfmgr[409]: %PLATFORM-SHELFMGR-3-SHUTDOWN_RESET : Node 0/0/CPU0 is reset due to admin shut/no shut request
RP/0/RSP0/CPU0:Nov 17 07:04:07.620 : shelfmgr[409]: %PLATFORM-SHELFMGR-3-MIXED_MEMORY_POWERED : Node 0/0/CPU0 is powered, system running mixed line card memory mode
RP/0/RSP0/CPU0:Nov 17 07:04:07.620 : shelfmgr[409]: %PLATFORM-SHELFMGR-3-MIXED_MEMORY_ALARM : System enters mixed line card memory mode
RP/0/RSP0/CPU0:Nov 17 07:04:45.623 : shelfmgr[409]: %PLATFORM-SHELFMGR-3-SHUTDOWN_RESET : Node 0/0/CPU0 is reset due to admin shut/no shut request
RP/0/RSP0/CPU0:Nov 17 07:05:56.743 : envmon[209]: %PLATFORM-ENVMON-3-ALARM_INDICATION : Raise alarm from CBC in slot 0/0/CPU0, alarm code CBC_ALRM_PWR_SEQ_FAILED
04-06-2017 04:23 AM
We have same bug with A9K-8T-L, do you have any solution?
04-06-2017 07:53 AM
On Trident this would be a HW fault. The board has to be replaced. CSCuz52900 is specific to Tomahawk line card generation.
04-07-2017 03:29 AM
It's very disapointing because that card worked only about 5 years...
02-04-2020 01:03 PM
Im fighting the smae issue Can anyone tell me what the fix is?
