Trouble with advertise a route BGP from VRF on Cisco IOS 7600
saul.reyes
the diagram especifie the actually operating network
we try to advertise the network 172.16.161.6 to Nortel devices and Cisco devices on cisco AS 2005 and 64912, if we are staying look the routing table on cisco 7600 the network 172.16.161.6 is know it
Success rate is 100 percent (5/5), round-trip min/avg/max = 20/24/28 ms
cisco 7600#trace
cisco 7600#traceroute vrf data 172.16.161.6
Tracing the route to 172.16.161.6
  1 189.1.11.5 [MPLS: Labels 581/730 Exp 0] 24 msec 24 msec 24 msec
  2 172.16.12.73 [MPLS: Label 730 Exp 0] 36 msec 28 msec 36 msec
  3 172.16.12.74 20 msec 20 msec 24 msec
  4 172.16.14.10 64 msec 20 msec 20 msec
  5 172.16.19.9 20 msec 24 msec 20 msec
  6 172.16.161.6 24 msec 20 msec 24 msec
PE_CAR_1#ping vrf data 172.16.161.6
Sending 5, 100-byte ICMP Echos to 172.16.161.6, timeout is 2 seconds:
but the devices Nortel on AS 64912 on routing tables don´t know the networ 172.16.161.6
the difference on cisco 7600 that know both AS 64912 and 2005 is this one:
configuration on Cisco Router 7600
router bgp 2006
bgp router-id 172.16.110.97
bgp log-neighbor-changes
bgp graceful-restart restart-time 120
bgp graceful-restart stalepath-time 360
neighbor 172.16.10.41 remote-as 64912
neighbor 172.16.10.41 description PP-A6
neighbor 172.16.11.233 remote-as 64912
neighbor 172.16.11.233 description PP-2TE2
neighbor 172.16.12.73 remote-as 2005
neighbor 172.16.12.73 description PE_MEX_1
neighbor 172.16.12.73 fall-over bfd
neighbor 172.16.13.9 remote-as 2005
neighbor 172.16.13.9 description PE_MEX_3
neighbor 172.16.13.9 fall-over bfd
neighbor 172.16.13.77 remote-as 2005
neighbor 172.16.14.6 remote-as 64512
neighbor 172.16.14.10 remote-as 64512
neighbor 172.16.16.26 remote-as 64982
neighbor 172.16.16.26 description INTERNET-2
neighbor 172.16.16.30 remote-as 64982
neighbor 172.16.16.30 description INTERNET-1
address-family ipv4
  neighbor 172.16.10.41 activate   (conexion to Nortel Devices)
  neighbor 172.16.10.41 route-map AS-PATH-MAN in
  neighbor 172.16.10.41 route-map REDES-WAN->MAN out
  neighbor 172.16.11.233 activate   (conexion to Nortel Devices)
  neighbor 172.16.11.233 route-map AS-PATH-MAN in
  neighbor 172.16.11.233 route-map REDES-WAN->MAN out
  neighbor 172.16.12.73 activate
  neighbor 172.16.12.73 route-map REDES-WAN-PE_MEX_1 in
  neighbor 172.16.12.73 route-map DEFAULT-ROUTE out
  neighbor 172.16.13.9 activate  (conexion to Cisco 7600 Devices)
  neighbor 172.16.13.9 route-map REDES-WAN-PE_MEX_3 in
  neighbor 172.16.13.9 route-map DEFAULT-ROUTE out
  neighbor 172.16.13.77 activate
  neighbor 172.16.13.77 route-map DEFAULT-ROUTE out
  neighbor 172.16.14.6 activate  (conexion to ASR 9000)
  neighbor 172.16.14.6 route-map default out
  neighbor 172.16.14.10 activate (conexion to ASR 9000)
  neighbor 172.16.14.10 route-map default out
the difference that look it from routes to know Nortel devices an Cisco Devices is the sollow on Cisco 7600
Cisco 7600#sho ip bgp 150.151.1.250
BGP routing table entry for 150.151.0.0/16, version 5612717
Paths: (2 available, best #1, table default)
Multipath: eBGP
  Advertised to update-groups:
     2          4
  2005
    172.16.13.9 from 172.16.13.9 (150.220.250.5)
      Origin IGP, localpref 300, valid, external, best
      Community: 100:22
      Extended Community: RT:100:22
  2005
    172.16.12.73 from 172.16.12.73 (150.220.250.1)
      Origin IGP, localpref 260, valid, external
      Community: 100:22
Cisco 7600#sho ip bgp 172.16.161.6
BGP routing table entry for 172.16.161.6/32, version 6133620
Paths: (2 available, best #2, table default)
Multipath: eBGP
  Not advertised to any peer
  64512 64513
    172.16.14.6 from 172.16.14.6 (172.16.14.1)
      Origin incomplete, localpref 100, valid, external, multipath
      Extended Community: RT:64512:64513
  64512 64513
    172.16.14.10 from 172.16.14.10 (172.16.14.2)
      Origin incomplete, localpref 100, valid, external, multipath, best
NOT advertised to any peer
if we looking on ASR the vrf GAT the network is advertised but on vrf CAMPUS not
RP/0/RSP0/CPU0:ED_MEX_1#sho bgp vrf CAMPUS 172.16.161.6
Mon May 20 12:58:03.516 UTC
BGP routing table entry for 172.16.161.6/32, Route Distinguisher: 64512:64513
Versions:
  Process           bRIB/RIB  SendTblVer
  Speaker                 20          20
    Local Label: 16004
Last Modified: May 17 17:24:29.877 for 2d19h
Paths: (1 available, best #1)
  Path #1: Received by speaker 0
  64513
    172.16.19.5 from 172.16.19.5 (172.16.162.4)
      Origin incomplete, metric 110, localpref 100, valid, external, best, group-best, import-candidate
      Received Path ID 0, Local Path ID 1, version 20
      Extended community: RT:64512:64513
but the vrf GAT:
RP/0/RSP0/CPU0:ED_MEX_1#sho bgp vrf GAT 172.16.161.6
Mon May 20 12:58:52.909 UTC
BGP routing table entry for 172.16.161.6/32, Route Distinguisher: 64512:2006
Versions:
  Speaker                 30          30
  Advertised to CE peers (in unique update groups):
    172.16.14.5
   172.16.14.5
  64513
      Origin incomplete, metric 110, localpref 100, valid, external, best, group-best, import-candidate, imported
      Received Path ID 0, Local Path ID 1, version 30
Any idea for this trouble, we try to advertise the extend community but nothing.
the configuration on ASR is the follow:
router bgp 64512
bgp router-id 172.16.14.1
address-family ipv4 unicast
address-family vpnv4 unicast
vrf GAT
  rd 64512:2006
   redistribute connected
   redistribute static
  neighbor 172.16.14.5
   remote-as 2006
    send-community-ebgp
    route-policy pass-all in
    route-policy pass-all out
    send-extended-community-ebgp
vrf CAMPUS
  rd 64512:64513
   redistribute static
  neighbor 172.16.19.5
   remote-as 64513
we only put send-extended-community-ebgp only on vrf GAT.
Best Regards
Harold Ritter
Hi Saul,
route-target extended communities are normally not sent to the peers in the VRF (ce). Can you remove the command
send-extended-community-ebgp from the neighbor in vrf GAT and try to see if the 7600 passes it on to the Nortel and Cisco devices.
Harold Ritter
Hi Saul,
Hi Harold thanks for your comment
We do it your recommendation and put on AS 64912 routes a route-map for identify the traffic IN on interface the finally configuration on cisco 7600 is:
router bgp 2006
neighbor 172.16.14.6 description EDGE_MEX_1
neighbor 172.16.14.10 description EDGE_MEX_2
address-family ipv4
  no synchronization
  neighbor 172.16.14.6 route-map REDES_CAMPUS in
  neighbor 172.16.14.10 route-map REDES_CAMPUS in
  neighbor 172.16.16.26 activate
with the follow route maps:
ip extcommunity-list standard GAT permit rt 64512:64513
ip bgp-community new-format
ip community-list standard REDES-GAT permit 64512:2006
route-map REDES_CAMPUS permit 430
match extcommunity GAT
set local-preference 250
set community 64512:2006 additive
set extcommunity rt  64512:64513 additive
route-map REDES-WAN->MAN permit 1600
match community REDES-GAT
with this information the routes advertise on neighbord know the loopback 172.16.161.6
GW_MEX_2#sho ip bgp neighbors 172.16.11.233 advertised-routes
BGP table version is 6160029, local router ID is 172.16.110.97
Status codes: s suppressed, d damped, h history, * valid, > best, i - internal,
              r RIB-failure, S Stale
Origin codes: i - IGP, e - EGP, ? - incomplete
   Network          Next Hop            Metric LocPrf Weight Path
*> 1.0.0.1/32       172.16.12.73                  300      0 2005 ?
*> 1.0.0.2/32       172.16.12.73                  300      0 2005 ?
*> 172.16.140.72/32 172.16.13.9                   300      0 2005 ?
*> 172.16.141.22/32 172.16.12.73                  250      0 2005 ?
*> 172.16.141.61/32 172.16.12.73                  250      0 2005 i
*> 172.16.141.71/32 172.16.12.73                  250      0 2005 i
*> 172.16.142.0/27  172.16.13.9                   300      0 2005 ?
*> 172.16.142.32/27 172.16.13.9                   250      0 2005 ?
*> 172.16.144.0/27  172.16.13.9                   300      0 2005 ?
*> 172.16.146.1/32  172.16.13.9                   300      0 2005 65451 i
*> 172.16.150.0/27  172.16.12.73                  250      0 2005 ?
*> 172.16.152.0/27  172.16.13.9                   300      0 2005 ?
*> 172.16.152.32/28 172.16.13.9                   300      0 2005 ?
*> 172.16.155.1/32  172.16.13.9                   300      0 2005 ?
*> 172.16.161.1/32  172.16.14.6              0    250      0 64512 ?
*> 172.16.161.6/32  172.16.14.10             0    250      0 64512 ?
Thanks for your cooperation
Best Regards
