UNTESTED output for admin diagnostic start location 0/0/CPU0 test all-test
sourabh2
I am getting below output with U keyword i.e. Untested
what is the meaning of this?  Is this kind of HW failure of testing?
please advise.
Test results: (. = Pass, F = Fail, U = Untested)
  ___________________________________________________________________________
  1  ) SrspStandbyEobcHeartbeat --------> U
          Error code ------------------> 0 (DIAG_SUCCESS)
          Total run count -------------> 0
          Last test execution time ----> n/a
          First test failure time -----> n/a
          Last test failure time ------> n/a
          Last test pass time ---------> n/a
          Total failure count ---------> 0
          Consecutive failure count ---> 0
  2  ) SrspActiveEobcHeartbeat ---------> U
mivens
SRSP tests are only run on the standby RP/RSP, not LCs. Are you sure you're not looking at the output of "show diagnostic result" for the active RSP or RP? The command "diagnostic start location 0/0/CPU0 test all-test" produces no ouput when I try it (asr9k/xr 6.5.3).
