Upgrade IOS XR from 4.3.4 to 5.3.3 ?!?
ima imtiger
Could you please tell me if I can upgrade XR from 4.3.4 to 5.3.3 ???
I can't find guide here
http://www.cisco.com/web/Cisco_IOS_XR_Software/index.html
Thank you for your answer
Ima
16 Replies 16
Hi, thanks for your comments! Do you have a document with the HW support (LC and RSP) for 5.3.3 and 6.4.2 in order to validate the HW installed in the router. What about for ASR9001? is similar to ASR9010 procedure? or there anything special case?
0/RSP0/CPU0     A9K-RSP440-TR(Active)     IOS XR RUN       PWR,NSHUT,MON
0/RSP1/CPU0     A9K-RSP440-TR(Standby)    IOS XR RUN       PWR,NSHUT,MON
0/0/CPU0        A9K-MOD80-TR              IOS XR RUN       PWR,NSHUT,MON
0/0/0           A9K-MPA-4X10GE            OK               PWR,NSHUT,MON
0/0/1           A9K-MPA-4X10GE            OK               PWR,NSHUT,MON
0/1/CPU0        A9K-MOD80-TR              IOS XR RUN       PWR,NSHUT,MON
0/1/0           A9K-MPA-4X10GE            OK               PWR,NSHUT,MON
0/1/1           A9K-MPA-4X10GE            OK               PWR,NSHUT,MON
0/2/CPU0        A9K-MOD80-TR              IOS XR RUN       PWR,NSHUT,MON
0/2/0           A9K-MPA-4X10GE            OK               PWR,NSHUT,MON
0/2/1           A9K-MPA-4X10GE            OK               PWR,NSHUT,MON
5.3.3 supports all the cards 4.3.4 does.
Here is the release note for 6.4.2, it will validate what cards are supported:
https://www.cisco.com/c/en/us/td/docs/routers/asr9000/software/asr9k-r6-4/general/release/notes/b-release-notes-asr9000-642.html
9001 uses same procedure for upgrade / turboboot.
Sam
