Use of Management Ethernet port on ASR9000
aacole
Level 5
Level 5
Are there any restrictions on the use of the management ethernet port in the asr9000?
I configured an ip address on the port, made it a member of the management vrf, but was unable to acces any of the remote routers in the same vrf via ssh. Is there anything else I need to enable to make this work?
if I console into a router I can ssh to any other router via the management vrf.
On the remote routers I could see the subnet that was applied to the management interface in the correct vrf.
Reading the manual today i see there is a command:
rp mgmtethernet forwarding
I didnt try this when on site, is this what I am missing?
Andy
Correct the mgmt interface doesn't participate in forwarding. it is local terminaton only.
google the supportforum doc on local packet transport services that has a write up on that also.
And indeed, the rp mgmt forwarding knob basically provides routing through the mgmt port, but that is not
something I would recommend using other then for lab testing. the mgmt ports are not hw accelerated.
thanks
xander
aacole
Level 5
Level 5
From the management ethernet port I can access the local router, but cannot SSH to any remote router using addresses in the same vrf.  However I can ssh to any router in the management vrf from the console port.
Here is the port config:
interface MgmtEth0/RSP0/CPU0/1
vrf MANAGEMENT
ipv4 address 10.1.1.104 255.255.255.0
This is part of the MANAGEMENT vrf route output on a remote box.
B    10.1.1.0/24 [200/0] via x.x.x.x (nexthop in vrf default), 00:06:33
S    10.222.26.0/26 [1/0] via 10.250.255.251, 3w3d, GigabitEthernet0/1/1/0
A remote router can ping 10.1.1.104, but not the PC conncted to the ethernet port, and yes, the PC firewall is off.
thanks
xander
Thanks Xander, it wasn't clear from the 4.3 Interface and Hardware config guide.
Andy
