Using local-as feature in XR 5.1.1 not working
ar
I am using local-as feature in version 5.1.1.
Seems not fully supported for iBGP.
here's my config:
router bgp 65068
 neighbor 1.1.1.1
  remote-as 100
  local-as 100 no-prepend replace-as
  address-family ipv4  unicast
!!% Change would result in neighbor (1.1.1.1) with same local-as and remote-as
I have tested in 5.2.0 and its working...
is there any additional configuration I need to make it work in version 5.1.1?
Swapnil Shingvi
hi Ar,
iBGP local-as feature is supported in XR starting in release 5.2.2. Hence you don't see it work in 5.1.1
Hope this helps,
Swapnil
Swapnil Shingvi
hi Ar,
Hope this helps,
Swapnil
thanks..
is there any work around so I dont need to upgrade?
