VRF ERROR
vin.marco
Hello
i have a problem with an ASR 9006.
I'm getting logs.
ipv4_rib[1169]: %ROUTING-RIB-5-TABLE_NH_DAMPED : Nexthops in Vrf: default Tbl: default (0xe0000000) Safi: Unicast are getting damped
0/RSP0/CPU0     A9K-RSP880-TR(Standby)    IOS XR RUN       PWR,NSHUT,MON
0/RSP1/CPU0     A9K-RSP880-TR(Active)     IOS XR RUN       PWR,NSHUT,MON
0/0/CPU0        A9K-MOD200-TR             IOS XR RUN       PWR,NSHUT,MON
0/0/0           A9K-MPA-8X10GE            OK               PWR,NSHUT,MON
0/1/CPU0        A9K-MOD200-TR             IOS XR RUN       PWR,NSHUT,MON
0/1/0           A9K-MPA-20X1GE            OK               PWR,NSHUT,MON
0/1/1           A9K-MPA-8X10GE            OK               PWR,NSHUT,MON
Cisco IOS XR Software, Version 6.2.3[Default]
What kind of problem can it be?
smilstea
I talked about this some in another thread a few days ago, https://community.cisco.com/t5/xr-os-and-platforms/asr9001-quarantined-0-0-0-0-0-route/td-p/4434983
Damped routes are caused by flapping of the route too quickly or the next-hop changing too often. The same commands from that thread will help tell us what the issue is.
Sam
