VRF manipulation in IOS XR 4.2.1
e_kniazev1974
I can't find feature list of IOS XR 4.2.1 for ASR9K and can't find it in release notes of IOS XR 4.2.1.
Does IOS XR 4.2.1 support VRF Selection Using Source IP Address or VRF Selection Using ABF?
If it is not possible, what is the solution instead?
Thank you.
7 Replies 7
Alexei Kiritchenko
here you can find release notes for 4.2.1
http://www.cisco.com/en/US/docs/routers/asr9000/software/asr9k_r4.2/general/release/notes/reln_a9k_421.html
VRF aware ABF is supported on ASR9k since 4.2.0.
/A
I found it earlier, but I don't understand how to configure IOS-XR router
like this on IOS router:
access-list 40 permit source 10.1.0.0 0.0.255.255
access-list 50 permit source 10.2.0.0 0.0.255.255
access-list 60 permit source 10.3.0.0 0.0.255.255
route-map PBR-VRF-Selection permit 10
 match ip address 40
 set vrf VRF1
route-map PBR-VRF-Selection permit 20
 match ip address 50
 set vrf VRF2
route-map PBR-VRF-Selection permit 30
 match ip address 60
 set vrf VRF3
interface Ethernet 0/1
 ip address 192.168.1.6 255.255.255.252
 ip vrf forwarding VRF4
 ip policy route-map PBR-VRF-Selection
 ip vrf receive VRF1
 ip vrf receive VRF2
 ip vrf receive VRF3
Here is a configuration example:
ipv4 access-list ipv4-abf
10 permit ipv4 any any nexthop1 vrf 1 ipv4 10.10.1.2 nexthop2 vrf 2 ipv4 20.20.1.2 nexthop3 ipv4 30.30.1.2
ipv6 access-list ipv6-abf
10 permit ipv6 any any nexthop1 vrf 1 ipv6 2100::2 nexthop2 vrf 2 ipv6 2200::2 nexthop3 ipv6 2300::2
interface TenGigE0/1/0/12
ipv4 address 25.25.25.1 255.255.255.0
ipv6 address 2040::1/64
ipv4 access-group ipv4-abf ingress
ipv6 access-group ipv6-abf ingress
/A
There is no PBR on XR. You'd need to use ABF for NH manipulation which is in another VRF.
vrf VRF777
40 permit ipv4 10.1.0.0 0.0.255.255 any nexthop1 vrf VRF1
50 permit ipv4 10.2.0.0 0.0.255.255 any nexthop1 vrf VRF2
60 permit ipv4 10.3.0.0 0.0.255.255 any nexthop1 vrf VRF3
/A
I am testing ABF on XR running on an old 12K in our lab, before upgrading few CRS in production.
Unforunately, cant seem to see ABF with NH as an option. I am running 4.2.3 in test.
Has thsi feature been scrapped off again ?
RP/0/3/CPU0:LAB-PE2(config-ipv4-acl)#permit ipv4 any any ?
  dscp           Match packets with given DSCP value
  fragments      Check non-initial fragments
  log            Log matches against this entry
  log-input      Log matches against this entry, including input interface
  packet-length  Check packet length
  precedence     Match packets with given precedence
TIA
/Samir
Hi Samir,
AFAIK, ABF isn't supported on XR12K but only on ASR9000 and CRS platforms.
Kind regards,
N.
