[vsm stuck on bringdown]
Carlos A. Silva
Level 3
Level 3
Hello, Everyone:
I'm trying to get a brand new VSM to boot. First time I installed it (by that I mean, just inserted it into an ASR9k with XR5.1.2), immediately went IOS XR RUN. At that point I had the service (only) PIE active. When I added and activated the service-infra PIE, the VSM rebooted itself as soon as PIE was active and it has stayed in BRINGDOWN state ever since. I've reloaded the slot several times to no avail. Any advice will be appreciated.
c.
Here's some info:
RP/0/RSP0/CPU0:XXXXXXXX#show platform
Tue Jan 20 22:01:39.674 CST
Node            Type                      State            Config State
0/RSP0/CPU0     A9K-RSP440-TR(Active)     IOS XR RUN       PWR,NSHUT,MON
0/RSP1/CPU0     A9K-RSP440-TR(Standby)    IOS XR RUN       PWR,NSHUT,MON
0/0/CPU0        A9K-MOD80-SE              IOS XR RUN       PWR,NSHUT,MON
0/0/0           A9K-MPA-4X10GE            OK               PWR,NSHUT,MON
0/0/1           A9K-MPA-4X10GE            OK               PWR,NSHUT,MON
0/1/CPU0        A9K-MOD80-SE              IOS XR RUN       PWR,NSHUT,MON
0/1/0           A9K-MPA-4X10GE            OK               PWR,NSHUT,MON
0/1/1           A9K-MPA-4X10GE            OK               PWR,NSHUT,MON
0/3/CPU0        A9K-VSM-500               BRINGDOWN        PWR,NSHUT,MON
RP/0/RSP0/CPU0:Jan 20 21:54:10.378 : shelfmgr[401]: %PLATFORM-SHELFMGR-3-SHUTDOWN_RESET : Node 0/3/CPU0 is reset due to admin shut/no shut request
RP/0/RSP0/CPU0:Jan 20 21:54:10.379 : shelfmgr[401]: %PLATFORM-SHELFMGR-6-NODE_STATE_CHANGE : 0/3/CPU0 A9K-VSM-500 state:IOS XR FAILURE
RP/0/RSP0/CPU0:Jan 20 21:54:10.469 : config[65896]: %MGBL-CONFIG-6-DB_COMMIT_ADMIN : Configuration committed by user 'mnet'. Use 'show configuration commit changes 2000000006' to view the changes.
RP/0/RSP1/CPU0:Jan 20 21:54:12.404 : canb-server[152]: %PLATFORM-CANB_SERVER-7-CBC_PRE_RESET_NOTIFICATION : Node 0/3/CPU0 , Power Cycle (0x05000000)
RP/0/RSP0/CPU0:Jan 20 21:54:12.407 : canb-server[152]: %PLATFORM-CANB_SERVER-7-CBC_PRE_RESET_NOTIFICATION : Node 0/3/CPU0 , Power Cycle (0x05000000)
RP/0/RSP0/CPU0:Jan 20 21:54:12.408 : shelfmgr[401]: %PLATFORM-SHELFMGR-6-NODE_STATE_CHANGE : 0/3/CPU0 A9K-VSM-500 state:BRINGDOWN
RP/0/RSP0/CPU0:Jan 20 21:54:12.412 : invmgr[263]: %PLATFORM-INV-6-NODE_STATE_CHANGE : Node: 0/3/CPU0, state: ADMIN DOWN
RP/0/RSP0/CPU0:Jan 20 21:54:32.473 : shelfmgr[401]: %PLATFORM-SHELFMGR-3-SHUTDOWN_RESET : Node 0/3/CPU0 is reset due to admin shut/no shut request
RP/0/RSP0/CPU0:Jan 20 21:54:32.475 : shelfmgr[401]: %PLATFORM-SHELFMGR-6-NODE_STATE_CHANGE : 0/3/CPU0 A9K-VSM-500 state:IOS XR FAILURE
RP/0/RSP0/CPU0:Jan 20 21:54:32.478 : invmgr[263]: %PLATFORM-INV-6-OIROUT : OIR: Node 0/3/1 removed
RP/0/RSP0/CPU0:Jan 20 21:54:32.563 : config[65896]: %MGBL-CONFIG-6-DB_COMMIT_ADMIN : Configuration committed by user 'mnet'. Use 'show configuration commit changes 2000000007' to view the changes.
RP/0/RSP0/CPU0:Jan 20 21:54:34.496 : canb-server[152]: %PLATFORM-CANB_SERVER-7-CBC_PRE_RESET_NOTIFICATION : Node 0/3/CPU0 , Power Cycle (0x05000000)
RP/0/RSP0/CPU0:Jan 20 21:54:34.497 : shelfmgr[401]: %PLATFORM-SHELFMGR-6-NODE_STATE_CHANGE : 0/3/CPU0 A9K-VSM-500 state:BRINGDOWN
RP/0/RSP0/CPU0:Jan 20 21:54:34.500 : invmgr[263]: %PLATFORM-INV-6-NODE_STATE_CHANGE : Node: 0/3/CPU0, state: BRINGDOWN
RP/0/RSP1/CPU0:Jan 20 21:54:34.505 : canb-server[152]: %PLATFORM-CANB_SERVER-7-CBC_PRE_RESET_NOTIFICATION : Node 0/3/CPU0 , Power Cycle (0x05000000)
RP/0/RSP0/CPU0:XXXXXXXX#admin show install active
Tue Jan 20 22:04:19.640 CST
Secure Domain Router: Owner
  Node 0/RSP0/CPU0 [RP] [SDR: Owner]
    Boot Device: disk0:
    Boot Image: /disk0/asr9k-os-mbi-5.1.2/0x100305/mbiasr9k-rsp3.vm
    Active Packages:
      disk0:asr9k-mini-px-5.1.2
      disk0:asr9k-services-infra-5.1.2
      disk0:asr9k-doc-px-5.1.2
      disk0:asr9k-fpd-px-5.1.2
      disk0:asr9k-mcast-px-5.1.2
      disk0:asr9k-mgbl-px-5.1.2
      disk0:asr9k-mpls-px-5.1.2
      disk0:asr9k-services-px-5.1.2
      disk0:asr9k-k9sec-px-5.1.2
      disk0:asr9k-9000v-nV-px-5.1.2
  Node 0/RSP1/CPU0 [RP] [SDR: Owner]
    Boot Device: disk0:
    Active Packages:
  Node 0/0/CPU0 [LC] [SDR: Owner]
    Boot Device: mem:
    Boot Image: /disk0/asr9k-os-mbi-5.1.2/lc/mbiasr9k-lc.vm
    Active Packages:
  Node 0/1/CPU0 [LC] [SDR: Owner]
    Boot Device: mem:
    Active Packages:
RP/0/RSP0/CPU0:XXXXXXXXX#
Yang Li
Dear Mr. Carlos,
I'm trying to install the VSM card to ASR9912, but we faced a similar issue.
1. First time,we use version 5.2.2, the State show BRINGDOWN.
2. And then we are upgrade the IOS to version 6.2.3, but the State still show
3. We are change IOS to version 5.3.3, but the state show PRESENT.
Could you let me know if your problem is solved? If solved, can you let me know how to solve it.
Thanks very much!
.ılı..ılı.
Cisco System
Pyhton
U got a dream, U gotta protect it
