weird XR Fan issues
anazarenko
Can anybody advise if it's hardware related?
RP/0/6/CPU0:Aug 16 16:45:23.168 : envmon_periodic[203]: %PLATFORM-ENVMON-2-FAN_CLEAR : The fan array (Ps Fan(slot 17)) has returned to a normal level.
RP/0/6/CPU0:Aug 16 16:46:16.884 : envmon_periodic[203]: %PLATFORM-ENVMON-2-FAN : The fan array (Ps Fan(slot 17)) has reached MAJOR level.
RP/0/6/CPU0:Aug 16 16:46:43.747 : envmon_periodic[203]: %PLATFORM-ENVMON-2-FAN : The fan array (Ps Fan(slot 16)) has reached MAJOR level.
RP/0/6/CPU0:Aug 16 16:47:10.609 : envmon_periodic[203]: %PLATFORM-ENVMON-2-FAN_CLEAR : The fan array (Ps Fan(slot 17)) has returned to a normal level.
RP/0/6/CPU0:Aug 16 16:47:37.469 : envmon_periodic[203]: %PLATFORM-ENVMON-2-FAN_CLEAR : The fan array (Ps Fan(slot 16)) has returned to a normal level.
RP/0/6/CPU0:Aug 16 16:48:31.187 : envmon_periodic[203]: %PLATFORM-ENVMON-2-FAN : The fan array (Ps Fan(slot 16)) has reached MAJOR level.
RP/0/6/CPU0:Aug 16 16:48:58.049 : envmon_periodic[203]: %PLATFORM-ENVMON-2-FAN : The fan array (Ps Fan(slot 17)) has reached MAJOR level.
RP/0/6/CPU0:Aug 16 16:49:24.914 : envmon_periodic[203]: %PLATFORM-ENVMON-2-FAN_CLEAR : The fan array (Ps Fan(slot 16)) has returned to a normal level.
RP/0/6/CPU0:Aug 16 16:49:51.777 : envmon_periodic[203]: %PLATFORM-ENVMON-2-FAN_CLEAR : The fan array (Ps Fan(slot 17)) has returned to a normal level.
RP/0/6/CPU0:Aug 16 16:50:45.492 : envmon_periodic[203]: %PLATFORM-ENVMON-2-FAN : The fan array (Ps Fan(slot 17)) has reached MAJOR level.
RP/0/6/CPU0:Aug 16 16:51:12.358 : envmon_periodic[203]: %PLATFORM-ENVMON-2-FAN : The fan array (Ps Fan(slot 16)) has reached MAJOR level.
here you go:
RP/0/1/CPU0:ios#admin sh env fan last
Thu Aug 16 18:56:28.277 CEST
Note: prior interval measurements shown
0/24/*    host  AllFansOk      Ok
          host  FanPowerOk     Ok
          host  FanArrayOk     Ok
5 Replies 5
Ivan Krimmel
Level 7
Level 7
you gotta check:
admin sh env temperatures
admin sh env fan
also physical examination would be good - the air filters could got dust etc.
Cheers!
RP/0/0/CPU0:ios(admin)#sh environment fans  last
Thu Aug 16 18:47:29.110 UTC
0/16/*    host  PowerFanOk     FAIL
          host  MainFanOk      FAIL
0/17/*    host  PowerFanOk     FAIL
          host  MainFanOk      FAIL
RP/0/0/CPU0:ios(admin)#sh environment  temperatures
Thu Aug 16 18:48:14.230 UTC
R/S/I   Modules Sensor          Temp. (deg C)
0/0/*     host  Inlet              36.5
          host  Hot                36.5
0/16/*    host  Inlet              31.0
          host  Hot                35.5
0/17/*    host  Inlet              29.5
          host  Hot                34.0
0/18/*    host  Inlet              24.0
          host  Hot                25.5
0/19/*    host  Inlet              26.5
          host  Hot                28.5
0/20/*    host  Inlet              25.0
          host  Hot                27.0
0/24/*    host  Inlet              31.0
0/26/*    host  Inlet              27.5
FAIL doesn't sound too good I must say, normally on a 12k with 4.x you should see FANs being rotating:
RP/0/5/CPU0:ios#admin sh env fan last
Thu Aug 16 12:14:51.076 CEST
                 Fan 0       Fan 1       Fan 2
R/S/I            (rpm)       (rpm)       (rpm)
0/28/*            3036        3120        3171
I am running 3.9.1 on it.
here you go:
          host  FanPowerOk     Ok
          host  FanArrayOk     Ok
