XFP-10GER-192IR+ and XFP10GER-192IR-L
Hi All,
I have to install transceivers ER in one ASR9010 and I have available two types: XFP-10GER-192IR+ and XFP10GER-192IR-L. I saw the compatibility matrix document and it says that I can use both types in one 8X10G Linecard. So my question is what is the difference between these two
transceivers ER.
Regards.
Samil Lama
Hello Jaime,
The XFP-10GER-192IR+ and XFP10GER-192IR-L are Cisco Multirate 10GBASE-ER/-EW and OC-192/STM-64 IR-2 XFP Module for SMF, rated for distances up to 40km with a maximum bandwidth of 10Gbps.
The difference between them is the power consumption: 3.5 W in XFP-10GER-192IR+ vs 2.5W in XFP10GER-192IR-L.
The -L in the end stands for "Low" consumption.
Regards.
would like to add the following:
XFP (LR/ER/ZR support multi-rate)
http://www.cisco.com/en/US/prod/collateral/modules/ps5455/ps6574/product_data_sheet0900aecd802a61b9.html
SFP+ (10GBASE-LW, 10GBASE-ZW)
http://www.cisco.com/en/US/prod/collateral/modules/ps5455/data_sheet_c78-455693.html
and in case you have typhoon liencards and more specificall the 24 or 36x10 then the following applies:
https://supportforums.cisco.com/docs/DOC-33778
xander
Thanks Xander.
And regarding dwdm XFPs, has CRS a restriction about the number of modules inserted in a slot?.
We have a 14x10GE PLIM with 4 dwdm xpf ( ports 0,2,4 and 6) and 2 LR xpf (ports 3 and 10). Now we want to install more dwdm and LR XPFs. Is there some restriction about this?.
Jaime.
Jaime, I would want to recommend opening a tac case on that if no one response to your question in a relatively short time. I am not familiar enough with the thermals of CRS and its airflow/CFM capacity. I dont believe there are similar restrictions, but best to make sure with someone who knows the crs thermals inside out.
regards
xander
