XR Licence Issues
richard.gosling
Hi All,
We are getting the errors in the log of the ASR9k
A9K-iVRF-LIC    :0/0/CPU0  :Mon Nov 26 10:55:35 2012: license_acquire: opaque_string (null), result('License Manager' detected the 'warning' condition 'Licensed feature does not exist')
A9K-AIP-LIC-B   :0/0/CPU0  :Mon Nov 26 10:55:35 2012: license_acquire: opaque_string (null), result('License Manager' detected the 'warning' condition 'No such license')
A9K-AIP-LIC-E   :0/0/CPU0  :Mon Nov 26 10:55:35 2012: license_acquire: opaque_string (null), result('License Manager' detected the 'warning' condition 'Licensed feature does not exist')
LC/0/7/CPU0:Nov 22 11:43:25.212 : rsi_agent[254]: %LICENSE-ASR9K_LICENSE-2-INFRA_VRF_NEEDED : 1 VRF(s) are configured without a valid license / license configuration A9K-iVRF-LIC in violation of the Software Right To Use Agreement. This feature may be disabled by the system without the appropriate license. Contact Cisco to purchase the license immediately to avoid potential service interruption.
LC/0/0/CPU0:Nov 23 11:38:01.834 : rsi_agent[254]: %LICENSE-ASR9K_LICENSE-2-INFRA_VRF_NEEDED : 1 VRF(s) are configured without a valid license / license configuration A9K-iVRF-LIC in violation of the Software Right To Use Agreement. This feature may be disabled by the system without the appropriate license. Contact Cisco to purchase the license immediately to avoid potential service interruption.
How can I check if the license's are installed correctly in the slots?
Any one have a guide on License's
Many thanks Rich
mdebraba
Guide is here:
http://www.cisco.com/en/US/docs/routers/asr9000/software/asr9k_r4.0/system_management/configuration/guide/b_yc40asr9k.pdf
And to check license status:
admin show license
admin show license allocated
admin show license available
But the messages above indicate something went wrong.  Have you performed any license restore ?  If yes you may have it a bug.  If you still have your .lic files and want to 'start from scratch' you can try the following:
(admin)#clear license
(admin-config)#no license xxx location
(admin-config)#commit
Then re-add the licenses.
mdebraba
Guide is here:
admin show license
Thanks Maxime
