HSRP/interface tracking problem
Marks Maslovs
Hi everyone,
I've decided to configure interface tracking for HSRP, to decrease priority value of the router in case of int failure. Pretty much straight forward.
Here is my config for HSRP:
router hsrp
Interface bvi52
address family ipv4
hsrp 3 version 1
priority 90
address 10.20.163.33
track GigabitEthernet0/0/0/10 20
The problem is that hsrp thinks that g0/0/0/10 is down, but it's actually not.
p.s. g0/0/0/10 is L2 interface.
RP/0/RSP1/CPU0:ASR9k-2#sh hsrp bvi52 detail
Wed Nov 21 15:08:03.587 EET
BVI52 - Group 3
  Local state is Active, priority 70
  Hellotime 3 sec holdtime 10 sec
  Next hello sent in 0.148
  Minimum delay 1 sec, reload delay 5 sec
  Hot standby IP address is 10.20.163.33 configured
  Active router is local
  Standby router is 10.20.163.34 expires in 00:00:07
  Standby virtual mac address is 0000.0c07.ac03
  4 state changes, last state change 09:08:44
  State change history:
  Nov 12 09:08:12.407 EET  Init     -> Listen   Delay timer expired
  Nov 12 09:08:22.409 EET  Listen   -> Speak    Standby timer expired
  Nov 12 09:08:32.411 EET  Speak    -> Standby  Standby timer expired
  Nov 21 05:59:19.590 EET  Standby  -> Active   Lower priority active received
  Last coup sent:       Nov 21 05:59:19.590 EET
  Last coup received:   Never
  Last resign sent:     Never
  Last resign received: Never
Tracking states for 1 object, 0 up:
    Down GigabitEthernet0/0/0/10 Priority decrement: 20
Show int g0/0/0/10 tells completely different story:
RP/0/RSP1/CPU0:ASR9k-2#sh int g0/0/0/10
Wed Nov 21 15:10:49.021 EET
GigabitEthernet0/0/0/10 is up, line protocol is up
  Interface state transitions: 3
  Hardware is GigabitEthernet, address is 6c9c.ed0d.9d9e (bia 6c9c.ed0d.9d9e)
  Description: RNC5_NPGEP11/0
  Layer 2 Transport Mode
  MTU 1514 bytes, BW 1000000 Kbit (Max: 1000000 Kbit)
     reliability 254/255, txload 0/255, rxload 0/255
  Encapsulation ARPA,
  Full-duplex, 1000Mb/s, LXFDX, link type is autonegotiation
  output flow control is off, input flow control is off
  loopback not set,
  ARP type ARPA, ARP timeout 04:00:00
  Last input 00:02:03, output 00:00:00
  5 minute output rate 0 bits/sec, 1 packets/sec
     84 packets input, 5058 bytes, 0 total input drops
     0 drops for unrecognized upper-level protocol
     Received 83 broadcast packets, 1 multicast packets
              0 runts, 0 giants, 0 throttles, 0 parity
     0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored, 0 abort
     636821 packets output, 39363916 bytes, 0 total output drops
     Output 59421 broadcast packets, 577338 multicast packets
     0 output errors, 0 underruns, 0 applique, 0 resets
     3 carrier transitions
Where could be the problem?
Thank You in advance!
mdebraba
Unfortunately IOS-XR tracks the state of the IPv4 interface, so interfaces without IP address will be considered down.  So this is the expected behavior, tracking doesn't work for L2transport interfaces.
mdebraba
Thank You very much for Your reply!
