XR OS / Bug tool question
startx001
Hi ,
Regarding bugs on XR platform , i cant find what means under known fixed releases  fourth number in XR version
Known Fixed Releases:
(7)
6.1.3.6i.BASE
6.1.31.3i.BASE
6.1.32.2i.BASE
6.2.1.25i.BASE
6.2.1 is version ? , and what means 25i ???
Example:
5.3.4 - IPv6 ACL not matching traffic for ACE with destination port
CSCvc22207
Description
Symptom:
Traffic not matching IPv6 ACL statements when Dest port is defined
Traffic with same Destination port as ACE doesn't match
permit udp eq
but matches statement
permit udp
Conditions:
Running code 5.3.4
Workaround:
Apply ACE without defining Destination port
Further Problem Description:
Customer Visible
Notifications
Save Bug
Open Support Case
Was the description about this Bug Helpful?
(0)
Details
Last Modified:
Feb 3,2017
Status:
Fixed
Severity:
2 Severe
Product:
(8)
Cisco ASR 9000 Series Aggregation Services Routers
Cisco IOS XR Software
Cisco ASR 9922 Router
Cisco ASR 9010 Router
Cisco ASR 9904 Router
Cisco ASR 9006 Router
Cisco ASR 9001 Router
Cisco ASR 9912 Router
Support Cases:
Known Affected Releases:
(1)
5.3.4.BASE
(7)
6.1.3.6i.BASE
6.1.31.3i.BASE
6.1.32.2i.BASE
6.2.1.25i.BASE
Aleksandar Vidakovic
When IOS XR release is in preparation, we are building an image for internal test purposes every week. The version number of the weekly build is the fourth nibble. When the testing is completed and we are ready to post the binaries to cisco.com, we cut the fourth nibble.
In other words, this is how to decompose 6.2.1.25i:
  • 6.2: major release number
  • 1: minor release number
  • 25i: pre-release (internal) version number.
Hope this clarifies,
/Aleksandar
