XR QoS - Possible to Guarantee Traffic on Ingress?
ODJ
Hej
I am working on a QoS profile for MPLS Customers. where I limit overall port traffic with a Parent policy, then use Child policy to limit some of the DSCP values on ingress.
For example: I limit Overall interface ingress BW to 100Mbps, and limit EF traffic to only 10% of that.
My issue is that I can not figure out how to guarantee the 10% EF traffic on ingress.
I see that if for example I send 1G BE traffic, I only see maybe 1% EF traffic or even less being passed. So there doesn't seem to be a filtering or buffering mechanism on ingress. Or none that I could find.
I would appreciate the help. Below is the config
###########PARENT POLICY###########
policy-map INGRESS-PARENT-100M
 class class-default
  service-policy INGRESS-CHILD
  police rate 100 mbps
 end-policy-map
###########CHILD POLICY###########
policy-map PM-ACCESS-IN-CHILD
 description STANDARD QoS child for CPE access with QoS
 class CM-ACCESS-IN-EF
  set traffic-class 5
  set mpls experimental imposition 5
  police rate percent 10
 class class-default
  set traffic-class 1
  set mpls experimental imposition 1
 end-policy-map
################CLASS-MAP############
class-map match-any CM-ACCESS-IN-EF
 match dscp ef
 end-class-map
ntikader
Hi Odj ,
Please suggest the plaftorm you want to apply this config , as QOS is H.W specefic   in all XR platforms and there can be limiation on specefic platfoms.
Hej ntikader
We are using NCS55A2 version 7.2.2
ntikader
Hi Odj ,
Regarding the QoS config  suggested is either incomplete or wrong config .
Also when using Parent Child polices it means you want to use  hierarchical qos policy  .
To enable HQoS on NCS5500 you need the  below global configuration command
hw-module profile qos hqos-enable”  ------ thsi require router reload
 class class-default
  service-policy INGRESS-CHILD where is this policy configured .
 end-policy-map
 Please check the below cco link for Do and Dont during QOS config in NCS platforms.
https://www.cisco.com/c/en/us/td/docs/iosxr/ncs5500/qos/70x/b-qos-cg-ncs5500-70x/b-qos-cg-ncs5500-70x_chapter_010.html#concept_B2623387F5114390BC8E06D0E2119D76
