XRv 9000 IPoE BNG
subscribers cannot ping to default-router, though subscriber connected properly Setup was done with VMware ESXi 6.5.
Thanks for clarifying. BNG feature parity between asr9k and xrv9k is should be achieved next year, in one of the 7.x upcoming releases. If your deployment model of xrv9k BNG requires ambiguous mode, please reach out to your account team at Cisco and let's work towards a resolution.
7 Replies 7
Aleksandar Vidakovic
You need to check whether the vBNG doesn't send the ICMP echo request properly or the CPE doesn't reply properly. Check the route and CEF entry for the subscriber's IPv4 address. Run 1000 pings with timeout zero and check the interface counters to see whether packets are sent/received. You probably need to do some troubleshooting on CPE as well.
Btw, you should also send the "default-router" from your DHCP server profile.
/Aleksandar
Added "default-router" option in dhcp profile and sent 1000 packet with timeout 0. Result is negative. Didn't find any increment in interface counter.
RP/0/RP0/CPU0:vBNG#show subscriber session all
Tue Aug 21 10:13:07.033 UTC
Codes: IN - Initialize, CN - Connecting, CD - Connected, AC - Activated,
       ID - Idle, DN - Disconnecting, ED - End
Type         Interface                State     Subscriber IP Addr / Prefix
                                                LNS Address (Vrf)
IP:DHCP      Gi0/0/0/1.ip1591         AC        10.10.37.42 (default)
IP:DHCP      Gi0/0/0/1.ip1590         AC        10.10.37.41 (default)
RP/0/RP0/CPU0:vBNG#show interfaces GigabitEthernet 0/0/0/1.ip1590
Tue Aug 21 10:13:27.474 UTC
GigabitEthernet0/0/0/1.ip1590 is up, line protocol is up
  Interface state transitions: 1
  Hardware is IP Subscriber interface(s), address is 000c.2929.5e21
  Internet address is 10.10.37.1/24
  MTU 1500 bytes, BW 1000000 Kbit (Max: 1000000 Kbit)
     reliability 255/255, txload 0/255, rxload 0/255
  Encapsulation Ipsub_base,  loopback not set,
  Last link flapped 00:04:21
  ARP learning is disabled
  Last input 00:00:00, output never
     244 packets input, 15661 bytes
     0 input drops, 0 queue drops, 0 input errors
     0 drops for unrecognized upper-level protocol
     0 packets output, 0 bytes
     0 output drops, 0 queue drops, 0 output errors
Tue Aug 21 10:13:37.133 UTC
GigabitEthernet0/0/0/1 is up, line protocol is up
  Hardware is GigabitEthernet, address is 000c.2929.5e21 (bia 000c.2929.5e21)
  MTU 1514 bytes, BW 1000000 Kbit (Max: 1000000 Kbit)
  Encapsulation ARPA,
  Duplex unknown, 1000Mb/s, link type is force-up
  output flow control is off, input flow control is off
  loopback not set,
  Last link flapped 3d22h
  Last input 00:00:00, output 00:00:11
  5 minute input rate 0 bits/sec, 1 packets/sec
     134989 packets input, 18720483 bytes, 42 total input drops
     Received 5333 broadcast packets, 0 multicast packets
              0 runts, 0 giants, 0 throttles, 0 parity
     0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored, 0 abort
     10236 packets output, 3510055 bytes, 0 total output drops
     Output 4465 broadcast packets, 0 multicast packets
     0 output errors, 0 underruns, 0 applique, 0 resets
     0 carrier transitions
RP/0/RP0/CPU0:vBNG#show route | i A
Tue Aug 21 10:13:42.419 UTC
       D - EIGRP, EX - EIGRP external, O - OSPF, IA - OSPF inter area
       N1 - OSPF NSSA external type 1, N2 - OSPF NSSA external type 2
       U - per-user static route, o - ODR, L - local, G  - DAGR, l - LISP
       A - access/subscriber, a - Application route
A    10.10.37.41/32 is directly connected, 00:04:36, GigabitEthernet0/0/0/1.ip1590
A    10.10.37.42/32 is directly connected, 00:00:40, GigabitEthernet0/0/0/1.ip1591
RP/0/RP0/CPU0:vBNG#ping 10.10.37.41 repeat 1000 timeout 0
Tue Aug 21 10:13:54.134 UTC
pings with timeout=0 may result in system instability and
control protocol flaps resulting in traffic impact.
Do you really want to continue[confirm with only 'y' or 'n'] [y/n] :y
Sending 1000, 100-byte ICMP Echos to 10.10.37.41, timeout is 0 seconds:
Success rate is 0 percent (0/1000)
RP/0/RP0/CPU0:vBNG#show configuration running-config dhcp ipv4
Tue Aug 21 10:14:19.270 UTC
dhcp ipv4
 profile DHCP-SERVER server
  lease 0 0 10
  pool IPv4-POOL-01
  dns-server 192.168.6.60
  default-router 10.10.37.1
 interface GigabitEthernet0/0/0/1 server profile DHCP-SERVER
Tue Aug 21 10:14:54.373 UTC
  Last link flapped 00:05:48
     318 packets input, 20101 bytes
Tue Aug 21 10:15:06.895 UTC
  Encapsulation ARPA,
  loopback not set,
  Last input 00:00:00, output 00:01:41
     135079 packets input, 18726243 bytes, 42 total input drops
With following configuration can ping to CPE
dhcp ipv4
  lease 0 0 10
  pool IPv4-POOL-01
RP/0/RP0/CPU0:vBNG#show configuration running-config pool
Tue Aug 21 10:18:47.798 UTC
pool vrf default ipv4 IPv4-POOL-01
 network 10.10.37.0/24 default-router 10.10.37.1
RP/0/RP0/CPU0:vBNG#show configuration running-config interface GigabitEthernet 0/0/0/1
Tue Aug 21 10:19:14.378 UTC
 ipv4 address 10.10.37.1/24
Can I ask you to do one thing: main physical interface as BNG subscriber access interface is a fairly new thing. I'm not sure whether it's officially supported on XRv9000. Can you try using a sub-interface instead of a main interface for subscriber access and let us know the outcome?
And also get the "show route x.x.x.x", "show cef x.x.x.x detail" and "show cef x.x.x.x internal".
/Aleksandar
Changing access interface from main interface to sub interface worked. Also "encapsulation ambiguous dot1q" wasn't applicable. Couldn't debug outputs of "show route, show cef, show cef internal". Outputs are as follows
Before:
Tue Aug 21 13:58:25.616 UTC
                                                LNS Address (Vrf)
IP:DHCP      Gi0/0/0/1.ip1650         AC        10.10.37.2 (default)
IP:DHCP      Gi0/0/0/1.ip1649         AC        10.10.37.1 (default)
RP/0/RP0/CPU0:vBNG#show route 10.10.37.2
Tue Aug 21 13:58:37.030 UTC
Routing entry for 10.10.37.2/32
  Known via "subscriber IPSUB_SUBSCR", distance 2, metric 0 (connected)
  Installed Aug 21 13:54:22.049 for 00:04:15
  Routing Descriptor Blocks
    directly connected, via GigabitEthernet0/0/0/1.ip1650
      Route metric is 0
  No advertising protos.
RP/0/RP0/CPU0:vBNG#show route 10.10.37.0
Tue Aug 21 13:58:38.996 UTC
Routing entry for 10.10.37.0/24
  Known via "connected", distance 0, metric 0 (connected)
  Installed Aug 21 12:13:42.672 for 01:44:56
    directly connected, via Loopback1
      Route metric is 0
RP/0/RP0/CPU0:vBNG#show route 10.10.37.1
Tue Aug 21 13:58:41.992 UTC
Routing entry for 10.10.37.1/32
  Installed Aug 21 13:51:39.276 for 00:07:02
    directly connected, via GigabitEthernet0/0/0/1.ip1649
      Route metric is 0
RP/0/RP0/CPU0:vBNG#show cef 10.10.37.1
Tue Aug 21 13:58:56.414 UTC
10.10.37.1/32, version 3547, attached, subscriber, internal 0x1000041 0x0 (ptr 0xd5d2e98) [1], 0x0 (0xd795be8), 0x0 (0x0)
 Updated Aug 21 13:51:39.278
 remote adjacency to GigabitEthernet0/0/0/1
 Prefix Len 32, traffic index 0, precedence n/a, priority 3
   via GigabitEthernet0/0/0/1.ip1649, 2 dependencies, weight 0, class 0 [flags 0x8]
    path-idx 0 NHID 0x0 [0xe6b0140 0x0]
    remote adjacency
RP/0/RP0/CPU0:vBNG#show cef 10.10.37.1 internal
Tue Aug 21 13:59:01.963 UTC
IPv4:default:0xe0000000[0x10c8e63b8]:rib:10.10.37.1/32[ref:1 proto:ipv4 flags:0x1000041 f2:0x0 src:rib][0x10d5d2e98]
  LDI => [ref:3 pl:0x10d5fc9b8 proto:ipv4 type:ip lvl:1 buckets:1 slots:1 fixup:0 flags:[owner locked, added to pl, depth changed, subscriber]][0x10d6af380]
    slots:
    {0,p0,s0}={
      NHINFO => [type:rx, linkt:link_IPv4, nh_proto:IPv4, ifh:GigabitEthernet0_0_0_1(0x1000048), adj:0x10d46d018, flags:[pd bind pending]][0x10e6b0140]
        IDB => [ref:1 ifh:0x1 type:0/none parent-type:0/none flags:[owner locked,remote,p2p][0x10c5dc2f0]
          IDB_EXT:{MPLS IPv4:NULL,IPv4:[ref:1 IPv4:default[0x10c8e63b8] NH:2 MTU:1500 flags:[none][0x10e5f6170]],MPLS IPv6:NULL,IPv6:NULL}
    buckets:
    {0,p0,s0}={[0x10e6b0140]}
  LDI_LW => [type:ip loadinfo:[0x10d6af380]][0x10d795be8]
  PATHLIST => [ref:2 count:1 depth:1 ldi:0x10d6af380 type:Shared flags:[subscriber] extn_flags:[]][0x10d5fc9b8]
    0={
      [[nh:0.0.0.0 ifh:GigabitEthernet0_0_0_1(0x1000048) tbl:0xe0000000 type:ip flags:[attached]]
      [depth:1 flags:[resolved,ldi-preferred] resolves-via: ###
            IDB_EXT:{MPLS IPv4:NULL,IPv4:[ref:1 IPv4:default[0x10c8e63b8] NH:2 MTU:1500 flags:[none][0x10e5f6170]],MPLS IPv6:NULL,IPv6:NULL} ###]}
After:
Tue Aug 21 14:13:49.907 UTC
                                                LNS Address (Vrf)
IP:DHCP      Gi0/0/0/1.1.ip1          AC        10.10.37.2 (default)
RP/0/RP0/CPU0:vBNG#ping 10.10.37.2
Tue Aug 21 14:13:53.894 UTC
Sending 5, 100-byte ICMP Echos to 10.10.37.2, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 1/1/2 ms
Tue Aug 21 14:14:17.611 UTC
  Installed Aug 21 14:13:33.280 for 00:00:44
    directly connected, via GigabitEthernet0/0/0/1.1.ip1
      Route metric is 0
RP/0/RP0/CPU0:vBNG#show cef 10.10.37.2
Tue Aug 21 14:14:25.544 UTC
10.10.37.2/32, version 3556, attached, subscriber, internal 0x1000041 0x0 (ptr 0xd5d3240) [1], 0x0 (0xd795be8), 0x0 (0x0)
 Updated Aug 21 14:13:33.283
 remote adjacency to GigabitEthernet0/0/0/1.1
   via GigabitEthernet0/0/0/1.1.ip1, 2 dependencies, weight 0, class 0 [flags 0x8]
    remote adjacency
RP/0/RP0/CPU0:vBNG#show cef 10.10.37.2 internal
Tue Aug 21 14:14:29.397 UTC
IPv4:default:0xe0000000[0x10c8e63b8]:rib:10.10.37.2/32[ref:1 proto:ipv4 flags:0x1000041 f2:0x0 src:rib][0x10d5d3240]
  LDI => [ref:2 pl:0x10d5fc9b8 proto:ipv4 type:ip lvl:1 buckets:1 slots:1 fixup:0 flags:[owner locked, added to pl, depth changed, subscriber]][0x10d6af380]
    slots:
    {0,p0,s0}={
      NHINFO => [type:rx, linkt:link_IPv4, nh_proto:IPv4, ifh:GigabitEthernet0_0_0_1.1(0x1001550), adj:0x10d46d148, flags:[pd bind pending]][0x10e6b0140]
    buckets:
  PATHLIST => [ref:1 count:1 depth:1 ldi:0x10d6af380 type:Shared flags:[subscriber] extn_flags:[]][0x10d5fc9b8]
    0={
      [[nh:0.0.0.0 ifh:GigabitEthernet0_0_0_1.1(0x1001550) tbl:0xe0000000 type:ip flags:[attached]]
Just as I expected, main interface is not supported yet. Can you clarify what you meant by "... wasn't applicable"? Ambiguous dot1q must work in the typical scenario: outer tag is explicitly configured and inner is ambiguous.
XRv9000 didn't support "encapsulation ambiguous dot1q {any | vlan-range }". I've used this command several time in BE interface on a physical A9K routers while configuring PPPoE BNG.
