unable to backup virtual blade (wave)
fernandezj
i try to backup virtual blade on FTP server but the msg appears:
WAAS-FR-TEST-CATS-WAVE294-1#copy virtual-blade 1 disk 1 ftp a.b.c.d / testbck.img
Enter username for remote ftp server: anonymous
Enter password for remote ftp server:
Put failed: File unavailable (e.g., file not found, no access)
You have a good idea???
best regards
Hi Fernand,
So FTP access seems to be fine.
Can you check the logs of the FTP server when you try to backup the VB to see if the WAVE is even trying to upload the file?
Can you also share your VM config?
Nicolas
Nicolas Fournier
Hi Fernand,
Can you check the FTP server logs and see what the WAVE is trying to do when you issue the command?
Does doing a "copy sysreport ftp ..." with he same parameters works fine?
Nicolas
Hi Nicolas,
I test with succes the command :
WAAS-FR-TEST-CATS-WAVE294-1#copy sysreport ftp x.x.x.x / sysreport.tar.gz
Generating sysreport ...
It is time consuming procedure. Please wait ...
14:30:45 ---Collecting Technical Support information ...
14:30:52 ---Collecting the system resource information ...
14:30:52 ---Collecting system alarm history ...
14:30:52 ---Collecting disk stats if any ...
14:30:52 ---Collecting disk systems partition information ...
14:30:53 ---Collecting Baseboard Management Controller (BMC) information ...
14:30:53 ---Collecting service logs ...
14:30:53 ---Collecting kernel logs ...
14:31:04 ---Collecting Accelerator statistics ...
14:31:06 ---Compressing sysreport ...
Successfully generated sysreport. Preparing to export via ftp
Initiating FTP upload...
Sending: USER anonymous
FileZilla Server version 0.9.37 beta
Password required for anonymous
Sending: PASS *********
Logged on
Sending: TYPE I
Type set to I
Sending: PASV
Entering Passive Mode (x,x,x,x,14,49)
Sending: CWD /
CWD successful. "/" is current directory.
Sending PASV
Entering Passive Mode (x,x,x,x,14,50)
Sending: STOR sysreport.tar.gz
Connection accepted
##############Transfer OK
#Sent 15540579 bytes
Hi Fernand,
Nicolas
Mummmmm...it's work now.....strange..but this morning i changed the right on FTP server....
it may be that , I'll do the test by submitting the original configuration..
thank's for you help nicolas
