Error opening tftp messages after successfully provisioning a new device
trylvis123
Hi everyone,
After successfully provisioning a new switch from APIC-EM, I see in the switch logs that there is a lot of error messages "error opening tftp://..", and wonder if this is common, and if so, is there any way to remove it? Is it related to the PnP profile?
I guess these errors are no big deal, but it would been nice to avoid them.
May  3 2017 08:30:30.363 CEST: %SYS-4-CONFIG_RESOLVE_FAILURE: System config parse from (tftp://255.255.255.255/cisconet.cfg) failed
%Error opening tftp://255.255.255.255/switch-confg (Timed out)
May  3 2017 08:31:05.498 CEST: %SYS-4-CONFIG_RESOLVE_FAILURE: System config parse from (tftp://255.255.255.255/switch-confg) failed
%Error opening tftp://255.255.255.255/switch.cfg (Timed out)
May  3 2017 08:31:29.588 CEST: %SYS-4-CONFIG_RESOLVE_FAILURE: System config parse from (tftp://255.255.255.255/switch.cfg) failed
%Error opening tftp://255.255.255.255/network-confg (Timed out)
May  3 2017 08:40:54.499 CEST: %SYS-4-CONFIG_RESOLVE_FAILURE: System config parse from (tftp://255.255.255.255/network-confg) failed
%Error opening tftp://255.255.255.255/cisconet.cfg (Timed out)
May  3 2017 08:41:18.578 CEST: %SYS-4-CONFIG_RESOLVE_FAILURE: System config parse from (tftp://255.255.255.255/cisconet.cfg) failed
%Error opening tftp://255.255.255.255/switchconfg (Timed out)
May  3 2017 08:41:53.727 CEST: %SYS-4-CONFIG_RESOLVE_FAILURE: System config parse from (tftp://255.255.255.255/switch-confg) failed
May  3 2017 08:42:17.828 CEST: %SYS-4-CONFIG_RESOLVE_FAILURE: System config parse from (tftp://255.255.255.255/switch.cfg) failed
aradford
it is harmless, but annoying.  The reason it is there is due to the autoboot process.  If there is no configuration file, the device will try to TFTP one from the local network.
You can disable it with the
"no service config"
command.  You can put this in your pnp configuration file.
Adam
8 Replies 8
aradford
"no service config"
Adam
Works like a charm, thanks alot!
glad we were able to resolve it quickly.
Adam
Thanks that was annoying...!
Hello
i have the same issue but a have not the hand to enter command
I have same problem in catalyst 2960 24 poe
but have not hand to write command
Thanks for. It was helpful for me on Switch C1000-24P-4G-L.
Muhibullah
Switch Ports Model SW Version SW Image
* 1 28 C1000FE-24T-4G-L 15.2(7)E4 C1000-UNIVERSALK9-M
Configuration register is 0xF
