Get Original Address from CTI Call Forwarding
mstromske
Question:  Can I retrieve the original address when I have a series of CTI ports chained together for call forwarding?
Example:
CTI x (Line 1 - "111")
Forward Unregistered Internal set to "222"
CTI y (Line 1 - "222")
Forward Unregistered Internal set to "333"
CTI z (Line 1 - "333")
CTI x and CTI y are unregistered.  CTI z is registered.  User dials "111".  CTI x forwards call to CTI y which forwards to CTI z.  CTI z processes the call.  Is there a way to retrieve the original address ("111") here?
Matt
mpotluri
Level 5
Level 5
call.getCalledAddress().getName() should return the original called party in this scenario. If you haven't tried it, can you try it and let us know?
