JTAPIProperties.updateCertificate failure reason= 0
derrickgunter
Level 5
Level 5
Trying to establish a TLS connection to CUCM and get this exception thrown when calling CiscoJtapiProperties.updateCertificate().
java.lang.Exception:  JTAPIProperties.updateCertificate : Certificate update failed, reason= 0 UpdateCertificate failed'
What does this mean?
Both the CTLFile.tlv.sgn and JtapiServerKeyStore-*-* files appear in the location specified by the cert path but the JtapiClientKeyStore-*-* file is missing.
Any ideas?
Thank you,
Derrick
Did you manage to fix this issue? I am having the same problem. I would be really grateful if you share your solution with me.
Thank you,
Yordan
