Call Control
Intro to Ansible
Good Documentation
The Great Selenelion
>> View previously featured conversations <<
Hello,I've seen multiple references to JTAPINotificationPort=2789, which is being opened on the JTAPI client side, as well as its description: "This field specifies the Port through which the JTAPI parameter changes are communicated to JTAPI applicat...
Hi,i am trying to use CTIPort as Monitor Initiator rather than IP phones. I believe CTIPort can be used. I get error as below. Please advise. 2018/05/30 10:08:06.457 EDT,INFO,Call event: 108, State: ACTIVE, Cause: CAUSE_DEST_NOT_OBTAINABLE, Addr: 514...
KasMay by • Visitor
  • 2420 Views
  • 5 replies
Hi Guys,I am wondering if somebody can provide me with a sample TCL script to be used in incoming dial-peer for SIP calls redirect on my CUBE gateway. I.e. I need to send SIP 3xx to ITSP, so they will redirect or divert this call accordingly and with...
My system is on windows 7 64 bit opearting system, and have used atapi dll in my dot net application to implement  atapi api.I have used  ATAPI Wrapper  of vesrion 1.4.0 will it create any issue?Or should I use atapi 64 bit? If yes then What would be...
Hello,working on a C890 Software (C890-UNIVERSALK9-M), Version 15.6(3)M1 I am facing a strange issue when trying to record both legsI am using an outgoing dial-peer to start a tcl script which dials an external number and conferences the 2 legs.When ...
A C by • Frequent Visitor
  • 2305 Views
  • 7 replies
Hello,     I have been going over the JTAPI documentation and see how to make calls, however I am trying to specifically "make" a call from an already existing terminal on a users computer by a single click of a button. The user doesn't have access t...
isaac.greer by • Community Member
  • 959 Views
  • 1 replies
Hello, I've found a fair amount of documentation that covers TCL scripts that reference elements/values of ISDN messages, but I cannot seem to find a specific example of a TCL script that captures the value of the UUI field. Does anyone have an examp...
majszakm by • Level 1
  • 3444 Views
  • 6 replies
Hi,I have created CTIPort in CUCM and able to get it in JTAPI code. Can some one tell me when and where to invoke setRTPParams ?.  Though i listen in CiscoMediaOpenLogicalChannelEv nothing happens.  CTI Port is in registered state.Thanks in Advance.
KasMay by • Visitor
  • 3688 Views
  • 6 replies
  • 1 Helpful votes
Hi,I am looking at integrating our call-record platform to work with Cisco HCS, and am having difficulty with the forked audio call. I have set up a recording profile, built-in-bridge etc in CUCM but when I receive the call, it shortly clears with a ...
We have an application that usually relies on a CTI app to obtain a caller's IP address and we'd like to see if we could implement something similar using a SIP Normalization script instead.What we would like to do is add a custom sip header to the o...
gboucher by • Community Member
  • 6308 Views
  • 8 replies
  • 1 Helpful votes
