09-10-2017 09:18 PM
Hi Cisco Team,
I have a requirement to monitor calls between telephony devices (e.g. a Cisco 7960 desk phone or soft phone). As soon as a call is placed, our software is supposed to provide a notification trigger which pops out a video display in our application. The display stays open until the call is terminated and thus an event trigger would be used to shut the video display down.
I have been looking at the various available options including TAPI - however as far as I can see, this appears to only work if the call is placed and received in a workstation that has a TAPI client installed and it is the one used for placing/receiving calls.
Is there any other API or way we can do this?
Randeep
Solved! Go to Solution.
09-11-2017 11:40 AM
TAPI (or JTAPI) can be used to monitor multiple phones/lines from the same application - which can certainly be a server app. The TAPI application will connect to CUCM via a configured 'application user' (or possibly a regular user account), and the CUCM admin can associated one or many phones to this app user - the application can then open and monitor events on any of the devices available in its associated device list.
There is also a mechanism whereby a TAPI/JTAPI application can dynamically 'acquire' control of a device ad hoc, based on its device name (see the 'super provider' feature info.)
09-11-2017 11:40 AM
09-11-2017 03:34 PM
Thank you, I will look deeper into the interface today. During the configuration of the TAPI, I didn't set it up as mentioned in your message. I will associate an Application user rather than an end user this time.
09-12-2017 01:01 PM
End user or Application user will work fine - the trick is in adding target devices to the 'Controlled Devices' list for the user.
