RingTone back is not working
Jean Lofrano
I have attached the last script version and the debug to check please.
The script flow is working properly but the I don't hear the ring tone.. I press the options and stay a "mute" period until someone answer the call.
thanks.
Guys!
I found out the problem. The router was not negociating the ring tone codec. I force codec config on dialpeer.
thanks.
wagnerm
I do not know the entire call flow or configuration but this worked for me a couple years back when callers didn't hear ringing.
sip-ua
disable-early-media 180
Thanks for suggestion.
But I tried to apply this command but same thing. All work very well, but I dont hear the ring tone.
Guys!
thanks.
