Call Control
Intro to Ansible
Good Documentation
The Great Selenelion
>> View previously featured conversations <<
Hi guys, I have been trying to migrate a TCL IVR script from 2900 to ISR router for days, but the router show a lot of erros.On debug process the most part of the functions are not compatible with the new platform.The script is very simple with optio...
We are using JTAPI as part of a Java 8/Spring Boot application to implement 1st and 3rd party call control on CUCM. The application currently runs in a Docker container (see Docker specs below). After reviewing the JTAPI Supported JVM Versions docume...
we have to reduce the ring time like as I dial PSTN number, IVR should run immediately. I tried to change the ivr pilot number one time it works great but after that ivr didn't start. Then reverted back. Configs & logs attached.  I am assuming this n...
Hi Team I want to use my currect TCL auto attended for new gateway. Existing gateway is working on pri line at the moment we will migrate it sip trunk between its. In my case incoming call will arrive via sip trunk. Can you please advice that my e xs...
KY_ by • Level 7
  • 5259 Views
  • 7 replies
Dear Cisco community, currently i work on a simple pyhton script to add one Calling Search Space with a few partitions.My testing enviroment:Pyhton 3.7 (Windows)zeep module (python to soap)CuCM 11.5 SU5 If i try to send the following code, my pyhton ...
rene.smole by • Frequent Visitor
  • 2362 Views
  • 2 replies
I use a tcl ivr application. Sometime when I reload script after some changings it hangs in loading process. Removing the application service and renaming it doesn't help. Only the router reboot helps. There isn't any hung session with this applicati...
oleg.syrbu1 by • Frequent Visitor
  • 4166 Views
  • 5 replies
Hi Team,I have successfully achieved Whisper coaching supervisor functionality with JTAPI & CUCM but I'm stuck on few things:- How to end Whisper Coaching?- Sometime whisper coaching not triggered? Code:try {int actionDelayMillis = Integer.parseInt("...
Hello community,We have a requirement to disconnect some outgoing calls (to the PSTN) after 5 minutes, but not to apply this config for some users (management). We are currently disconnecting all calls (incoming and outgoing) after 5 minutes, but thi...
Host_009 by • Level 1
  • 4063 Views
  • 3 replies
Hello Team, Together with my customer we are working on a CUCM config assurance script and the goal is to query certain CUCM parameters via AXL, verify them and display the misconfigured parameters to users so they can correct CUCM configuration on w...
mkorab by • Cisco Employee
  • 2555 Views
  • 3 replies
