04-06-2019 05:35 AM - edited 04-06-2019 05:37 AM
I am doing a PCD upgrade for the IMP servers and it cannot continue after the first server because the (PAWS) service is down amongst a few others on the primary. Using the 12.5(1) latest upgrade file.
What is the fix for this Cisco?
04-09-2019 11:39 PM
04-10-2019 02:18 PM
I was told by TAC to try this on the IMP server, then restart server.
set replication-sync monitor disable
I am going to test this tomorrow. If you test earlier please let me know!
04-11-2019 12:09 AM
Hi Michael,
Yes i was told the same from TAC.
and it works like a charm :) so great news. i already faced this issue twice on 2 different migrations...
Nat
04-11-2019 12:11 AM
05-04-2019 08:08 AM
Hi guys,
It works for me. I was doing the upgrade from 11.5 to 12.0.
Thanks for the tip.
05-05-2019 02:16 PM
07-11-2019 03:23 AM
Needed to use this on a 11.5 SU3 to 12.5 SU1 upgrade. I didn't reboot the servers after applying the command, and they started all the services on their own. I'll still reboot though. Saved me a TAC call!
08-16-2019 02:27 AM
Yep agreed. Looks like this is just generally a good idea after you upgrade.
05-31-2020 05:19 AM
This saved me a call to TAC also when I upgraded from 11.5(1)SU5 to SU7. Thank you!
06-01-2020 05:55 AM
HeatherHoffman73013 you are welcome. We work hard to share information and really appreciate when you take the time to consume it and it makes a difference.
Thank you for your effort and thanks for the feedback!
09-20-2019 06:29 AM
I have ran this command and it did not work for me.. Presence Engine still showing in starting state. Version 12.51.11900-117. Anything else I can try?
10-02-2019 01:09 PM
@TracyLogan2685 Did you resolve your issue? I am running into the exact same issue you are on a fresh install.
10-08-2019 05:38 PM
Hi Joe ,
Any luck with the service issue ? , i have run in to same issue as well .
Thilina
10-08-2019 05:48 PM
Did you run the command and then reboot the IM&P server? Then wait about 5-10 minutes after it reboots.
