Cisco local controller
cetmyron
What are the limitations of ciscobusiness.cisco local controller compared to paid license controller
4 Accepted Solutions
Mark Fang
Are you referring to the Cisco Business Wireless Access Point Controller? If so, the Cisco Business Wireless AP Controller is free and does not require a license.
However, if you are inquiring about the Cisco Business Dashboard, an installation includes licenses for up to 25 devices. For any devices beyond this limit, additional device licenses must be purchased.
Functionality remains the same regardless of whether you have a paid license or not. However, if you exceed the 25-device limit without buying sufficient licenses, the Cisco Business Dashboard will operate in a read-only mode.
cetmyron
Thanks Sir Mark Fang.
This refers to Cisco Business Dashboard.
CBW AP controller is free.
This question is specific to CBW and is beyond my expertise. Please create a new post in the wireless forum.
13 Replies 13
Mark Fang
Thank you for this Sir, if if connect to the ip address of cisco ap cbw 150ax this is the "Cisco Business Wireless Access Point Controller"?
Yes, it is.
"Functionality remains the same regardless of whether you have a paid license or not" this refers to Cisco Business Wireless Access Point Controller and Cisco Business Dashboard right?
Thank you for your help Sir, I can now access my 21 cbw150ax, i have 21 ap's. one ap acting as primary on which i use to connect to cbw ap controller, is it normal that it show only 20 ap's bacause i use the 1 ap as primary?
Where did you see the number of 20 APs?
>wireless settings
>access points..
ok sir, thanks for all the help appreciate it.
cetmyron
Another thing Sir Mark, this "25-device license for cisco business dashboard" (LS-CBD-25-1Y), how and where (website) to activate this? does this license goes directly to my clients account or to me first then ill transfer it later to his account.... please enlighthen me on how this licensing works...thank you verry much..
By the way sir I am a System Integrator i aslo supply equipments...
The license is held in your Cisco Smart Account. Once you obtain the license, you can refer to this document Cisco Business Dashboard License Activation to activate the license in your Cisco Business Dashboard.
Regarding the purchase and addition of the license to your Smart Account, I recommend contacting the support team and opening a case. The contact numbers for support can be found at Cisco Support.
