Audio delay in connecting voice with Jabber
pvarenholt
Level 5
Level 5
Running Jabber 12.1.1.1 via MRA and locally within our LAN.
Have multiple users with complaints of audio not connecting however calls seem to show connected - just no audio.
We have made sure automatically start calls with video is off.
can take up to 15 to 20 seconds  for the audio to start working.
Any recommendations or places i can start to look?
thanks,
paul.
7 Replies 7
Ratheesh Kumar
hi there
Is this only for MRA calls, then well, I am afraid if you are hitting this bug. Since there is no Workaround listed, I suggest you to open a case to move forward.
https://bst.cloudapps.cisco.com/bugsearch/bug/CSCuy89100/?rfs=iqvred
Symptom:
Jabber iPhone users cannot hear the first 2-3 seconds of audio after the call is answered.
Conditions:
1.Jabber iPhone is connected via MRA.
2.User receives a call on Jabber iPhone and answers it.
Workaround:
None
Hope this Helps
Cheers
Rath!
***Please rate helpful posts***
Thanks for the information.
This is not only with MRA but internal calls as well.
Paul.
I am also dealing with the issue. It does not affect every user, but those who do experience it all have laptops.  Desktop users aren't affected.  For those that experience it,  It occurs on internal Jabber calls, Jabber calls over VPN and over MRA. Repeated Cisco TAC tickets and working with our vendor have yielded no progress.
Have you sent them wireshark captures as well?
Paul.
Hi Paul,
 Yes. I've sent wireshark captures, RTMT trace logs, MRA logs, VPN logs, Jabber problem reports - you name it.  All to no avail.
Another thing - do you have the option to start calls with Video turned off for both parties as I found that causes delay in video trying to negotiate.
Paul.
In all test instances, the video option was turned off.
