Cisco IP Phones lost connection
Daniov1
Hi ,
Cisco IP Phones losing connection with CUCM Server 11.5SU4.
All the phones are losing connection on the same time.
I downloaded callmanager logs from RTMT and saw the following:
34198973.000 |03:35:16.218 |SdlStat |Period: 6s #Lines: 186 #Bytes: 32634 Total Number of Buffers: 10000 Free LWM: 9971 Free LWM(total): 7477
34198972.001 |03:35:16.218 |AppInfo |LineControl(26857) - registered with Duplicate DeviceName SEP001DA21ADF3, force the device to do the reregister: single device case
34198974.000 |03:35:16.218 |SdlSig |StationOutputReset |restart0 |StationD(2,100,66,62041) |LineControl(2,100,178,26857) |3,100,14,4898499.22^10.10.8.155^SEP001DA21ADF3 |[R:N-H:0,N:0,L:0,V:0,Z:0,D:0] duplicatePid=0.0.0.0 DevicePoolVersionStamp= DevicePoolHash= ResetType=2
34198974.001 |03:35:16.218 |AppInfo |StationD: (0062041) StationReset resetType=2.
34198975.000 |03:35:16.290 |Created | | |SdlTCPConnection(2,100,14,335797) |SdlTCPListener(2,100,12,3) | |NumOfCurrentInstances: 2324
34198976.000 |03:35:16.290 |SdlSig |SdlConnectionInd |wait |StationInit(2,100,65,1) |SdlTCPConnection(2,100,14,335797) |2,100,12,3.163827^*^* |*TraceFlagOverrode
34198976.001 |03:35:16.290 |AppInfo |New connection accepted. DeviceName=, TCPPid = [2.100.14.335797], IPAddr=10.10.8.155, Port=50659, Device Controller=[0,0,0]
34198976.002 |03:35:16.290 |AppInfo |Waiting for the first KeepAlive Message from the station... DeviceName=, TCPPid = [2.100.14.335797], IPAddr=10.10.8.155, Port=50659, Device Controller=[0,0,0]
34198977.000 |03:35:16.290 |SdlSig |SdlDataInd |wait |StationInit(2,100,65,1) |SdlTCPConnection(2,100,14,335797) |2,100,14,335797.2^10.10.8.155^* |*TraceFlagOverrode
34198977.001 |03:35:16.290 |AppInfo |StationInit: (0000000) InboundStim - StationRegisterTokenReqID
34198977.002 |03:35:16.290 |AppInfo |StationInit: (0000000) InboundStim - StationRegisterTokenReqID: Msg Size(received, defined) = 36, 52
34198977.003 |03:35:16.290 |AppInfo |StationInit: (0000000) Allow token request for SEP001DA21ADF3@10.10.8.155, though device w/same name already exists @10.10.8.155
34198977.004 |03:35:16.290 |AppInfo |StationInit: (0000000) Sending StationRegisterTokenAck registerQueueDept: 0 tokenQueueDepth: 1
I saw on the documents the following:
16: DuplicateRegistration - Unified CM detected that the device attempted to register to two nodes at the same time. Unified CM initiated a restart to the phone to force it to re-home to a single node. No action is necessary; the device will re-register automatically.
I need to investigate the reason of this issue.
Any suggest?
If it affects all phones at the same time, that sounds like either a problem with the call manager service on the affected node or network reachability problems to the affected node.
Is this a single phone or more than one phone?
Suggestion: Pulling the log from the phone itself will tell you from the phone's perspective what is causing it to attempt duplicate registrations.
Maren
