05-29-2012 04:46 PM - edited 03-17-2019 02:20 PM
I have a VCS to CUCM connection and the calls between a VC unit and a Jabber for Windows works well including video.
The issue that I have is when the VC unit disconnects the call the JFW client conversation pane does not close, it remains open as an active call with the timer still counting. It does not prevent me from making another call to that extension the conversation panes stack up. When making calls between clients registered on the CUCM this pane closes automatically.
If I login with my CUPC client I only get voice but the conversation pane does close in this situation.
05-30-2012 03:32 AM
Is the client in deskphone or softphone mode? Is the behavour the same in both modes?
Is it possible to obtain a wireshark trace to assist us in determining whether it is a client or server side issue?
Shane
05-30-2012 04:42 AM
05-30-2012 05:59 AM
Can you please open a TAC case and attach a problem report please?
Shane
06-13-2012 04:22 PM
Hi Heath,
Just wanted to see if you found the cause of the problem. We are currently experiencing the same issue but only when we call two of our users. Everything within UCM appears to be configured identically so i'm assuming it's an mis-config on the clients.
Kyle
06-18-2012 09:02 PM
Hi Kyle,
When the call remains on the CUCM cluster it is all good for me. The issue is only experienced when we are calling a VC system attached to a neighboured VCS and when the VC unit ends the call the pane stays active.
You you have a simular setup?
06-14-2012 12:36 AM
Hi Kyle,
Shane is on holidays for a while, I can see what I can do to help out. I think a prt would be a good start and our engineers can have a look at it and see why the conversation window is staying around.
If you can get us that Kyle we should be able to make progress.
Derek
06-14-2012 10:38 AM
Will do!
Thanks Derek.
