08-29-2019 01:40 AM
We are currently working on CUCM 11.5 upgrade to 12.0 customer is OK with the Direct model ..& customer said the IP address for CUCM is with the internet access given...how do we cross check that after upgrade done how CUCM 12.0 version is running with the Internet access...
Solved! Go to Solution.
08-29-2019 07:18 PM
To verify internet connectivity from CUCM, SSH to the CLI of CUCM IP and then use below command to ping to any public IP Address such as 8.8.8.8 or 8.8.4.4. If you get reply from these IP then it means your CUCM has access to internet.
utils network ping 8.8.8.8 utils network ping 8.8.4.4
08-29-2019 04:59 AM
08-29-2019 09:57 PM
08-29-2019 07:18 PM
