08-28-2023 03:34 AM
I tried to configure cucm with ldap and when I do full sync no users coming from AD, I checked cisco DirSync logs but nothing show there related to ldap, and tried to restart cisco DirSync service and do full sync again but still same issue
Solved! Go to Solution.
08-28-2023 04:47 AM
08-28-2023 04:03 AM
Take a packet capture of the sync and check with wireshark, if CUCM sends the request and gets something back.
But to me, it sounds as if you just don't find any users with your LDAP settings. You can verify it with an AD browser app and use the same LDAP settings like in CUCM.
08-28-2023 04:14 AM
But there is nothing on cisco DirSync logs, which mean traffic not coming out from cucm
08-28-2023 04:18 AM
But the logs in RTMT are showing traffic on a different layer. That's why I said, capture the traffic.
You don't need to follow advices.
08-28-2023 04:20 AM
There is no cli access to server only GUI
08-28-2023 04:22 AM
Then you should get access. You cannot manage and troubleshoot it, when you don't have full access.
And what about my other suggestion using an AD browser application?
08-28-2023 04:41 AM
I can to manage access ssh, can you please share command line, and if will effect on production?,
08-28-2023 04:47 AM
https://community.cisco.com/t5/collaboration-knowledge-base/packet-capture-on-cucm-appliance-model/ta-p/3118507
No, it will not effect anything.
08-28-2023 05:29 AM
Download Softerra LDAP Browser and check the connection with the credentials you used in CUCM LDAP Directory configuration.
08-28-2023 06:22 AM
When I put on ldap object path: domain only like dc=x,dc=x,dc=x it works, but when add OU on ldap object path: ou=x, dc=x,dc=x,dc=x, it doesn't work
08-28-2023 06:32 AM
Then you probably have a problem in the LDAP side and not in CUCM. Ask the responsible LDAP technician for further help.
