09-24-2013 11:56 AM - edited 03-17-2019 03:33 PM
Phones or devices registered directly to our UCM are able to join CWMS meetings just fine.
All CWMS functionality working fine other than this dial-in scenario. A remote office is setup with a new DID for local calls going to CWMS. This DID is translated to the normal CWMS call-in number on UCM. The call goes through and CWMS answers. Once you input the meeting ID and hit # the call drops.
PRI --(G711)--> MGCP VG --(G729 WAN)--> TxPattern on UCM --(stays G729)--> CWMS
-PRI and MGCP voice gateway are located in the remote office
-UCM and CWMS are located at the main office
UCM 8.6.2
CWMS 1.1.1.316.A
Solved! Go to Solution.
09-25-2013 03:45 AM
Hi Aaron,
looks like you are running into a codec missmatch.
Whats the region of your SIP Trunks to CWMS?
Are you using a transcoder? If yes, is this assigned to the GW-MRGL and the Trunk-MRGL?
Best regards
Ben
09-25-2013 03:45 AM
Hi Aaron,
Best regards
Ben
09-25-2013 03:09 PM
Thanks, that was it. My CWMS MRGL didn't include the transcoding resources my GW MRGL was using. Added those to my CWMS SIP trunk MRGL and all is working!
Aaron
02-03-2014 01:37 AM
I’m having this issue where calls into CWMS drop after pressing the # after the meeting ID. However for me it happens for internal calls from my CIPC as well as calls in from the PSTN (SIP).
Anyone else had/having this issue?
Matty
02-03-2014 05:12 AM
Hi Matty,
This is a common issue if the SIP configuration on CUCM side is not complete. Please, refer to this documentation for configuring all the needed parameters for proper SIP routing and Refer to CWMS Application Server and Loadbalancer:
http://www.cisco.com/en/US/docs/collaboration/CWMS/1_5/Planning_Guide_chapter_0110.html
I hope this will help you.
-Dejan
02-03-2014 06:27 AM
Many thanks Dejan,
I followed the 'The Ultimate Cisco WebEx Metting Server Lab' http://www.youtube.com/watch?v=podEaKLJ1Y4 but on the SIP trunk configuration it does not cover the 'Rerouting Calling Search Space'.
My setup is working after making this change.
Many thanks for your help.
Matty
02-03-2014 06:50 AM
Great, Matty. I am glad you were able to fix it.
Take care,
-Dejan
02-11-2016 07:41 AM
Hi Matty,
I have similar problem, how can I watch this video? What was the solution? Thanks a lot!
Anton
02-11-2016 12:05 PM
Hi Anton,
Sorry I don't know why the video has been made private! :-(
If you are getting the same error I did then as I said the issue for me was the rerouting CSS, have a look at the link that Dejan posted.
Good luck!
Matty
02-11-2016 12:28 PM
Hi Matty,
you saved me:) that fixed it! thanks a lot
02-11-2016 12:31 PM
Great news!
Rating always welcome ;-)
