06-11-2013 06:22 AM - edited 03-17-2019 03:18 PM
Hi group,
I meet an issue with Jabber and CUC. When a failover is done on my primary voicemail server, Jabber is not able to connect to secondary server.
Here is the profile used:
Furthermore when primary CUC server come back, Jabber is no more able to connect to this one. I need to log out and log in again.
Have you already this issue?
Here are versions used:
- Jabber release 9.2(1)
- CUCM 9.1.1.10000-11
- CUC 9.1.1.10000-32
Samuel
Solved! Go to Solution.
06-11-2013 09:34 AM
Hi Samuel,
I would say you're hitting this bug http://tools.cisco.com/Support/BugToolKit/search/getBugDetails.do?method=fetchBugDetails&bugId=CSCud63427
Unfortunately as of now there's no fix but it'll come out on a later release.
Please remember to rate helpful responses.
06-11-2013 09:34 AM
Hi Samuel,
06-11-2013 11:42 AM
Thanks Joshua!
06-04-2014 11:58 PM
Hi I now have jabber 9.7
Unity Connection 10
CUCM 10
Is this bug still valid?
11-10-2015 11:02 PM
Could be that I hit also this bug. Jabber didn't connect to second voicemail server, when primary is down.
My Versions:
Jabber version: 11.1.1 Build 22531 and Jabber 11.1(0)
CUCM version: 10.5.2.12901-1
CUC version: 10.5.2.12901-1
Will open a TAC case and look what he tell me about that.
best regards
Ben
11-12-2015 06:45 AM
I'm too having the same issue with jabber 11.1.1. Anyone having any solution?
